Originally Posted By: Triton_330
What size of cup wrench are you using if I may ask?
Triton
Sorry missed this...
I was speaking generally, I don't have a cup wrench specifically for this one AFAIK - though I have quite a few from my dealer days so I might have one to fit. This filter will usually get changed by someone else...
Oh... Well, see...
The reason I asked is because I used one on my truck (I know, I'm supposed to use the XG2 rather than XG10575, but both have the same gasket, threads, and relief pressure) - and well, I couldn't get it off the last time I went to change my oil. And I'm the one who put it on (by hand) the last time. It's weird, I swear every time I've used a Fram, it's like the seal gets tighter and thus impossible to take the filter off. One time before I used a PH2, and the same thing happened just like I'm having issues now with the XG10575...
I *cannot* get it off by hand. And I didn't put it on too tight, I always make sure of it. So it's gotta be something about Fram's gaskets that increase the seal pressure or something.
So, the reason I asked, is because either I'm gonna need to know what cup wrench can fit this so I can get one and take it off myself the next time I change my oil... Or, I'm gonna have to take it to my local mechanic (run by people I know and trust, almost family friends what with the amount of business my dad has had with them and his vehicles), which will cost me more than doing it myself [obviously].
If it's possible, would you be able to tell me the size of cup wrench that would fit on a 10575? (If not, no worries).
~ Triton
I have also put on filters by hand and was careful to not over tighten the filter. Then not be able to get the filter off by hand. This is not specific to FRAM.
1. A swivel wrench is not ideal, but will work in a pinch.
2. Since you know which filter is on the truck, you could go to the auto parts store and try the cup wrenches on a new filter with same PN.
My 2 cents.
