Where do you buy super cheap reading glasses?
by MoneyJohn - 02/20/20 11:34 AM
Caliper Boot Was Loose When Changing Pads
by Fitz98 - 02/20/20 11:15 AM
Non-Detergent and Additized Mono-Grades
by MolaKule - 02/20/20 11:14 AM
$25 Pennzoil rebate on 1 case of 6 qts
by Ride_Red - 02/20/20 08:28 AM
Ratcheting Wrenches
by Redright9 - 02/20/20 07:27 AM
Buick Regal 2.0T Ecotec Engines
by ET16 - 02/20/20 06:34 AM
Fuchs Titan GT1 Evo 0w20 LL014FE
by kr_bitog - 02/20/20 05:46 AM
Tungsten Ravenol
by V10 - 02/20/20 01:37 AM
Can an SSD make this much difference?
by 14Accent - 02/20/20 01:14 AM
The Big Oil Change - Sinclair Oil 1960's
by StevieC - 02/19/20 10:47 PM
A new topper for my truck
by HM12460 - 02/19/20 10:12 PM
AAP/Carquest platinum pads/rotors
by parshisa - 02/19/20 10:03 PM
Apple watch - high data usage
by Quattro Pete - 02/19/20 09:46 PM
Gas in the 80's vs Today
by alcyon - 02/19/20 09:34 PM
1993 Hilux 3.0 diesel
by Mayberryminitruc - 02/19/20 08:58 PM
WrightGrip 2.0 wrench set
by spasm3 - 02/19/20 08:57 PM
Don't forget about your clutch fluid
by Number_35 - 02/19/20 08:40 PM
Financial Advice
by cpayne5 - 02/19/20 08:28 PM
Jason454, Max331, 4fordsd, Mayberryminitruc, DaiwaGuy
70759 Registered Users
101 registered members (ABomb369, 750IX, Anduril, apollo18, 53' Stude, aquariuscsm, 10 invisible), 2,090 guests, and 21 spiders.
Topics301,697
Posts5,200,820
Members70,759
QSAD 5W20 VOA Bottled 2/25/16 #4104925 05/24/16 05:29 AM
dustyroads Offline OP
This oil came out of a 5 quart jug with a February 25, 2016 bottling date. It went into my Taurus recently and is my fourth consecutive time using this oil (QSGB/QSAD). When I get the results for my UOA of the oil I recently drained, I suspect it will show the same additive package as this. Not too impressive to look at but...
While I still like this oil, it is clearly different from my first two oci's of use. Instead of my engine being silent from inside the car (windows up), it is now audible until the oil gets warmed. It becomes fairly quiet after 12-15 miles of driving. There's never "noise" or clatter, just the hum of a V6 engine going about it's business. I suppose that's a good case of the add-pack getting activated.
Please understand that when I say my engine is silent/fairly quiet from inside the car, I'm speaking of low rpm and light/medium load. Typically, it's operated under 1,500 rpm with steep hills requiring as much as 2,200 rpm.
Quaker State Advanced Durability 5W20 (analysis by ALS Tribology,Atlanta)
Iron 0
Chromium 0
Lead 0
Copper 2
Tin 2
Aluminum 2
Nickel 0
Silver 0
Titanium 0
Vanadium 0
Silicon 4
Sodium 12
Potassium 0
Water <0.05%
Magnesium 3
Calcium 1863
Barium 0
Phosphorus 609
Zinc 764
Moly 153
Boron 85
Viscosity cSt @ 100C 8.5
Viscosity cSt @ 40C 50.5
TBN 6.6 (yes, that's what it says)
I took the liberty to change the <1 that ALS uses to 0's.
2013 F150 XLT 5.0 4X4 122k miles
Re: QSAD 5W20 VOA Bottled 2/25/16 [Re: dustyroads] #4104944 05/24/16 05:51 AM
wemay Offline
Definitely different from PQIA's last VOA of it...
PQIA 12/04/13
http://www.pqiamerica.com/Nov2013/QuakerState.htm
2019 VW Passat Wolfsburg TSI
VW High Performance Genuine Engine Oil 0W-20
OEM
2013 Hyundai Santa Fe Sport 2.0T
Shell Rotella Gas Truck 5W-30
OEM
Re: QSAD 5W20 VOA Bottled 2/25/16 [Re: wemay] #4105181 05/24/16 10:27 AM
wemay, thanks for linking the PQIA test. That was the reason I tried the QSGB in the first place and was so happy with this oil.
I knew something was different but it's still doing fine once the oil gets some heat in it. If PQIA should happen to test this oil again and it still has good viscometrics, I may stick with it. Otherwise, I can see myself maybe trying something different.
I sure wish QS had left it alone.
Re: QSAD 5W20 VOA Bottled 2/25/16 [Re: dustyroads] #4105355 05/24/16 01:19 PM
smithph Offline
Question for the guru's... Does the lower boron equate to more noise?
Fear, uncertainty and doubt are excuses to do nothing!
Re: QSAD 5W20 VOA Bottled 2/25/16 [Re: dustyroads] #4105413 05/24/16 02:21 PM
B
BigD1 Offline
B
Something had to give since Walmart and Firestone are using it for their standard service now. Not saying it's bad oil, but it has crossed my mind that there is a good probability that some penny pinching is going on now.
1992 Toyota Pickup--AmazonBasics Conventional--10W-30--Toyota 90915YZZD1
Re: QSAD 5W20 VOA Bottled 2/25/16 [Re: dustyroads] #4105757 05/24/16 08:44 PM
G
Garak Offline
G
I wouldn't be terribly concerned. We always have different tests by different labs, and the VOA can only tell you so much. A VOA is best for preparing for a trended analysis program, not for comparing whether one formulation is better than another, and that's assuming there's actually been a change.
Plain, simple Garak.
Re: QSAD 5W20 VOA Bottled 2/25/16 [Re: Garak] #4105899 05/25/16 03:47 AM
Garak, do you ever tire of being level headed and sensible? thumbsup
I posted the voa numbers immediately after opening the email from ALS and was quite disappointed at the time. It just looks like a drop in detergents and the tbn was surprisingly low (to me). I'm sure that the oil that I just drained was of the same formula because the engine became audible from inside the car last September when I put it in. I'm waiting for the uoa results to arrive but I expect it to be fine.
I just got a good feeling with the previous formulation as it was so quiet (from inside the car) at any temperature. This new stuff has to warm up first. To be fair, the sound was consistent throughout the entire 5,500 miles. That's more than I can say about other oils I had used previously in the same car.
Re: QSAD 5W20 VOA Bottled 2/25/16 [Re: dustyroads] #4106031 05/25/16 07:53 AM
G
Garak Offline
G
Well, you never know what method they're using for TBN, either. One can get different numbers, and that's why certain labs also have different condemnation levels.
And believe me, I'm as guilty of staring at VOAs and having ideas run through my head as the next guy here. I know that a VOA is most useful when starting a trended UOA plan, using the same oil and the same lab. That doesn't stop me from poking my nose into this section and reading every new post, and wondering about changes, or seeing levels where I "don't think" they should be.
I've seen several examples here where people ran the exact same oil at more than one different lab, and came out with significantly different numbers. So, we do need to exhibit some caution with the results, and like I said, stick with one lab for one VOA and trended UOA combination. And, we have to watch what we glean from the information, too.
Re: QSAD 5W20 VOA Bottled 2/25/16 [Re: Garak] #4106163 05/25/16 10:33 AM
I'm trying to stay with one oil (QSGB) and I have loaded up on NAPA kits going to ALS Tribology labs. Happy with both so far. My ALS test results match my older Blackstone uoa's so there was consistency in that aspect.
I thought that ALS used the ASTM D4739 method but now I can't find that info to say for sure. They may use the D2896 method on new oil and D4739 for used oil. Sorry I can't say for sure.
I tested the QSGB because I knew something was different last September and figured that I should get a fresh voa if I were to keep using it.
Re: QSAD 5W20 VOA Bottled 2/25/16 [Re: smithph] #4106200 05/25/16 11:28 AM
At the risk of getting pummeled by the formulators, I will say my opinion (based on my oil experiences) is the Boron does have an effect. This thread was started because I could hear a difference in sound level inside my car while using the same brand and viscosity oil. The newer QSGB oil has much less boron and it corresponds with a different sound level. Previously, I couldn't hear my engine from inside the car, now I can. Not loud, but it's there.
My other observation was when I had a Volvo truck with a D11 engine. That engine had a considerable amount of chatter coming from the massive geartrain, when idling or easing across a parking lot at low load. Delo 400LE with 500-600 ppm of boron, absolutely quieted the chatter from day one until it was drained 20k miles later. No other oils had that effect.
I obviously can't prove that the Boron was the reason for either of my examples but if not, what a coincidence. I'm not a guru...just my experiences.
Re: QSAD 5W20 VOA Bottled 2/25/16 [Re: dustyroads] #4106286 05/25/16 12:36 PM
G
Garak Offline
G
That seems sensible to me. Now, you have a VOA going forward again.
Re: QSAD 5W20 VOA Bottled 2/25/16 [Re: dustyroads] #4106436 05/25/16 03:30 PM
53' Stude Online Content
Online Content
Dustyroads: thank you for this VOA smile
2009 Toyota Camry LE
161,669 miles
Valvoline Maxlife Synthetic 5w20 Dexos 1 Gen 2 SN+
Fram tough guard 4386 filter
Re: QSAD 5W20 VOA Bottled 2/25/16 [Re: 53' Stude] #4106661 05/25/16 07:11 PM
You're welcome sir! thumbsup
Re: QSAD 5W20 VOA Bottled 2/25/16 [Re: dustyroads] #4107146 05/26/16 10:36 AM
Online Content
smile
161,669 miles
Re: QSAD 5W20 VOA Bottled 2/25/16 [Re: dustyroads] #4107398 05/26/16 04:19 PM
MolaKule Offline
Global Moderator
Global Moderator
I would suspect it is a coincidence.
There are just too many variables in an oil that could account for slightly higher noise levels. For example, the base oils used are mixes of at least two or more base types and base oil viscosities.
For example, if the lower viscosity oil in the mix predominates then there could be a more pronounced engine noise.
Boron is a cold temp AW and FM and would have little affect on engine noise.
I'm a Student Pilot. Frightening, isn't it?
