Originally Posted By: alarmguy
Originally Posted By: tig1
Why would anyone use a semi-syn 0-20 when so many full syn 0-20s are available? Cost? In a $30-$50K truck.
Because engine manufacturers know that conventional oils have a benefit not found in straight synthetics. But bottom line is, no matter the oil, if it meets what the manufacturer calls for your good to go, all apples, just different flavors.
The only advantage of conventional oil is lower cost. There is no other advantage in protecting the engine at any temp and at any engine speed.
