Doing a little reading on this oil & found the 10w30 has half the NOACK value of all the rest of the oils....how is it possible ? If using the same base stock (Pure Plus Technology) is the additive pack that different that it lowers the volitility of the oil that much ? Just trying to understand how the 10w30 has a value of 5.7 NOACK & the others range from 11-13 NOACK. Would the 10w30 be a viable option to replace running 5w30 in a state that rarely sees temps below 15-20 degrees in the winter ? Just thinking the lower NOACK would help with valve deposits in my direct injection engine, or is my thinking wrong.
