EWPE, your Fiat uses a factory coolant that would be the equal of Volkswagen's old G-11, BMW's blue coolant, Pentosin's Pentofrost NF, and Glysantin's G-48 coolant.This type of coolant uses a sacrificial corrosion inhibitor that makes coolant replacement mandatory in the 3-4 year time frame.
An upgrade to VW's G-13 (TL-774J) would be a wonderful upgrade and it is perfectly compatible with the coolant that you presently have in your system. This is convenient because it is nearly impossible to get a complete system flush when doing a coolant change.
My recommendation would be to source Glysantin GG40 if you can find it at an auto store. If not available then VW/Audi will be your source for the G-13. Always use distilled water since most water in Europe has heavy mineral deposits which cause contamination even with high quality coolants.
The current Fiat coolant is a perfectly acceptable fluid also. BMW has remained with this coolant for ages.
You're lucky to have access to Glysantin products freely. I'd look for:
GG40 (current VW G-13)
G40 (former VW G-12++ and still available)
G30 (former VW G-12)
or your current fill of G-48 (VW TL-774-C, BMW N600 69.0). The G48 requires replacement on 3-4 year basis while the other products are listed at lifetime which means 5 year/160,000km basis.
