Originally Posted By: DBMaster
No need to do anything to the rotors unless you have a problem, like runout (pulsation). I had a 93 Escort that used to go through pads every 20,000 miles (probably could have benefited from more expensive pads). Once, the outer right pad wore down quicker than the others and one of the rivets grooved the rotor. It was a clean groove and nearly in the middle of the rotor. I just slapped in new pads and kept going - no problem. All that grinding on the rotors, if not needed, accomplishes is shortening their lifespans.
I agree, and do the same thing on my 1995 Escort. I get way more miles on my front pads than you do. At 228 K miles, I think I have changed them, twice.
