Here's a VOA for Pennzoil Ultra Platinum 5w20. I had Blackstone do the TBN using both their old and new methodology. Under the new it is 8.9 and old is 11.0.
BLACKSTONE COMMENTS: This is your virgin Pennzoil sample, and it's got a nice, stout additive package. Almost all engine oils use calcium, phosphorus, and zinc as additives; the only difference is how much each one uses. This oil also has molybdenum and boron in it. Molybdenum, phosphorus and zinc are anti-wear additives. The rest are mainly detergent/dispersants. The TBN starts out quite strong at 8.9 using the new method, and it read 11.0 using the old method. No moisture or insolubles found, and the viscosity is correct for a 5W/20. This oil should work nicely in your vehicles.
Sample Date 09/06/14
ALUMINUM 0
CHROMIUM 0
IRON 1
COPPER 0
LEAD 0
TIN 0
MOLYBDENUM 54
NICKEL 0
MANGANESE 0
SILVER 0
TITANIUM 2
POTASSIUM 0
BORON 126
SILICON 2
SODIUM 2
CALCIUM 2330
MAGNESIUM 19
PHOSPHORUS 735
ZINC 821
BARIUM 0
SUS Viscosity @ 210°F 52.7
cSt Viscosity @ 100°C 8.10
Flashpoint in °F 460
Fuel % -
Antifreeze % -
Water % 0.0
Insolubles % 0.0
TBN (New Methodology) 8.9
TBN (Old Methodology) 11.0
ALUMINUM 0
CHROMIUM 0
IRON 1
COPPER 0
LEAD 0
TIN 0
MOLYBDENUM 54
NICKEL 0
MANGANESE 0
SILVER 0
TITANIUM 2
POTASSIUM 0
BORON 126
SILICON 2
SODIUM 2
CALCIUM 2330
MAGNESIUM 19
PHOSPHORUS 735
ZINC 821
BARIUM 0
Fuel % -
Antifreeze % -
Water % 0.0
Insolubles % 0.0
