Need to replace the transmission fluid on my 1988 w126 300sel. The transmission does have a short engaging delay when switching from (R)Reverse to (D)Drive. I'm wondering if the change in fluid will correct or at least make the engaging a bit quicker.
My buddy used a RED LINE fluid for his honda civic tranny that was slipping all over the place and believe it or not, the Redline tranny fluid made the slipping go away.
My transmission shifting on the road is excellent and like I mentioned before, there is only a delay in the tranny engaging from Reverse to Drive. Car has 74k documented miles and it seems too early to have ANY issues other than suspension rubber parts. Please advise on which type of tranny fluid is best to use on my car.
