I would stick with a 30 weight. Mobil 1 0w40 might be ok at operating temp, but at start up it will be much thicker.
Depends on what you are comparing it to and at what temp. At -35C I'll take the 0w-40 over a conventional 5w-30
Dont think that is an issue for the OP
I'm sure Colorado gets reasonably cold though
@ 40C, PYB is 63.9cSt vs 75cSt for the 0w-40. Not much of a difference.
At -40C, PYB isn't pouring. M1 0w-40 is 31,000cP. At -35C, M1 0w-40 is roughly half that @ ~15,500cP. PYB 5w-30 is 15,900cP (heavier).
And the slopes would go that way for a bit (the 0w-40 being lighter) up until they cross at some point below 0C.
So it all just depends on your reference temperature
