Hello All,
I am looking to do a transmission drain/filter replacement on the Audi in my signature. Although Audi considers this a "lifetime fluid", these 5 speed ZF transmissions were known for torque converter issues. Thus, I want to start doing drains every 20k mi or so.
Currently, the transmission seems to have some quirks. There are rather harsh downshifts at low speed and there is a noticeable amount of shudder when stopped in drive (although no slipping or shuddering any other time). There is also some noticeable delay from R to D. The transmission does not leak at all.
Anyway, the plan is to replace 3 quarts of fluid on the first drain (That is the drain amount, 9 quarts total capacity). I'll probably do two more drains at 1k mi intervals to fully refresh the fluid while not shocking the system.
I want to use Valvoline MaxLife Dex/Merc as it is what they recommend for this transmission. The OEM Pentosin is expensive enough it might be made from unicorn tears. Any thoughts on this fluid or another?
Also, once fully cycled, I would like to drop in some LubeGard. I've heard good things, but I'm not sure whether red or platinum is better for my application. Any tips there?
Thanks!
Thanks!
