The engine runs in our Doosan fork lift and it is the non-T version. We bought it brand new 4 years ago and there are 230 hours on the engine. The spec plate states to change the oil every 100 hours. Cummins spec sheet states to change the oil every 250 hours or 6 months.
So...as You can see we use it very rarely. 6 month are too low, 250 hours are too high for OCI. The factory fill was already changed at 100+ hours which I would say is the right term for changing the oil.
My problem is that last winter this little beauty started very badly and sucked down the battery. The truck is in the industrial district of the city so there were about -32°C in the morning and I could not manage to unload a semi. It was quite disappointing that the only important startup in about two weeks went wrong. Battery was/is strong enough. It was deffo the oil which was too thick.
On the other hand in the summer there could be almost 40°C ambient and at that temperature countinously using low viscosity (let's say artic) oil is not recommended by Mr. C.
In this matter I'm asking for Your advice. What kind of oil should I use in the upcoming term to find the golden path?
