Originally Posted By: JimPghPA
I usually buy a X type lug nut wrench and if the vehicle has hard to remove hub-caps I cut off the lug-nut socket opposite the one that fits the car, or sometimes it is the lug-nut socket that is least likely to ever be needed that I will cut off. I then shape the remaining shaft to be a large screw-driver blade with the end of the blade at 45 degrees when the x wrench is laying on the ground. The 45 degree blade angle makes it easy to get between the hub-cap and the tire rim, and then with a small twist, tough to remove hub-caps can be easily removed.
Kinda like getting the blade end of a simple tire iron and the advantages of a X wrench allowing you to use both hands to apply torque, all in one tool once you add the blade tip modification.
Good idea, but I just want a small tire iron to keep in my car and not take up too much space.
