Working on organizing my lube station at the farm and getting online to order som more grease guns since most of ours are gone/broken.
Got me thinking of how many varieties of grease We need.
Aside from a good lithium EP2 (i was thinking about chevron delo, but its tough to get so IDK) what else is needed?
We are a large dairy farm, primarily greasing equipment, chassis, bearings, wheel bearings, motors, and a few other things.
Do I need some grease with moly as well.
I know I'll have on setup with "corn head" grease.
I know I could go look through every manual to see what they want, but figured I'd see what other large shops are doing.
Im looking at having a pistol grip gun with whip hose setup with each different type of grease, then with the refill tubes below it.
For the general EP2 grease that will get used most I'll have a lever gun as well, along with a lever gun with top straight hard discharge, and the electric gun as well. This covers everybodys bases. I prefer the lever gun and for the most used grease we can justify having both, but for the other greases the pistol grip is a little more universal incase you need to hold the fitting on the nipple. The hard pipe discharges are much nicer for doing booms and things out in the open versus a hose.
We already have an alemite electric gun, the other guns I was looking at were from Alemite or Lincoln for the hand ones, although the clear ones at the top of this section look nice.
I was thinking about doing a keg for the most used stuff, but IDK.
For grease brands I have ready access to anything NAPA carries as well as Citgo and Mobil. Others like Chevron and Mystik I could get but it would take a little extra work.
Thanks for any input.
