Best Garage Door Seals
by Gebo - 11/17/19 07:18 PM
Bar oil as fogging oil
by WA1DH - 11/17/19 06:47 PM
Fram PH2 ExtraGuard Cut Open
by A310 - 11/17/19 06:38 PM
C&P Pentius UFXL PH16-equiv.
by 92saturnsl2 - 11/17/19 06:18 PM
Fleetguard WF2074 Coolant Filter Cut Open
by Pyrotechnic - 11/17/19 05:24 PM
Cuts on tire sidewall
by mclasser - 11/17/19 03:19 PM
Hyundai Theta II Engine in Newer Years
by smc733 - 11/17/19 02:41 PM
Walmart deals
by Deere John - 11/17/19 02:33 PM
Grumpy Kid
by wings&wheels - 11/17/19 01:57 PM
h9/95R FLA Batteries
by TXCarGeek - 11/17/19 01:40 PM
Preventative parking brake service
by Donald - 11/17/19 01:26 PM
Should I run an AC Delco Ultraguard gold?
by JHZR2 - 11/17/19 01:13 PM
Ford Ecoboost 400 at Homestead Miami Speedway
by bdcardinal - 11/17/19 01:08 PM
Strut mount, Moog vs KYB?
by jbutch - 11/17/19 01:07 PM
Is bar and chain oil hard on rubber?
by jqgz - 11/17/19 12:53 PM
TSC - Mobil Delvac $10.99
by Greg L - 11/17/19 12:42 PM
Wifi Thermostats
by FA_WRX - 11/17/19 10:33 AM
Test drove a few trucks. Ram Pentstar V6?
by dja4260 - 11/17/19 10:15 AM
2010 Corolla LE Opinions
by maverickfhs - 11/17/19 10:06 AM
XTR74, 2009Caraman, redmonkey01, gnouhp, tiblow
69896 Registered Users
141 registered members (53' Stude, 2009Caraman, 4WD, 330indy, 77GrandPrix, 20 invisible), 2,418 guests, and 26 spiders.
Topics297,560
Posts5,118,004
Members69,896
Most Online3,589
Nov 2nd, 2019
just started another kreen cycle.. #2914014 02/20/13 07:02 PM
E
electrolover Offline OP
E
I just added my first dose to the current fill in my F150. Half in the gas and half in the oil. Never added it to gas before..
Anyway my current fill has 800 miles on it and still looks like new oil. The oil never gets very dark on the stick with 5k ocis so I will be monitoring color as one point of reference. I will also be taking oil fill pics and disectecting the filter afterward. I have current fill hole pics for reference.
My plan is to run 4 quarts threw the engine, both in the gas and oil in this oci. But that is subject to change depending on other factors. I hope this becomes a thread filled with remarkable results!
Re: just started another kreen cycle.. [Re: electrolover] #2914024 02/20/13 07:08 PM
L
LeakySeals Offline
L
So you added Kreen to oil with 800 miles on it?
And its the same oil you always use so you will know by the stick if its unusually dark?
How long do you plan to leave it in the oil?
06 Escalade 6.0L LQ9 AWD 170k M1 5w30
03 Maxima 3.5L 170k Maxlife HM 10w30
05 Malibu Classic 2.2 111k M1 5w30
06 Altima 2.5L 167k unk
Re: just started another kreen cycle.. [Re: electrolover] #2914033 02/20/13 07:20 PM
E
E
It evaporates so im going to add more when the oil level drops back to full or 1000 miles, oci legth depends on the condition of the oil, but im aiming for 4k
Fyi every oil I have ran in it stayed pretty clean on the stick. The engine has no sludge, just varnish so there is really nothing for it to dissolve that would discolor it. See my other thread on page 2 or 3 labeled 5.4 with varnish for reference pics.
So far I have ran PP, PU, synpower, napa syn, Formula shell syn, gtx hm, etc in this truck. The darkest drains were when MMO or Kreen was added to the oil.
It has a 7 quart sump btw, and its my opinion that the extra capacity helps the oil to look clean longer.
Re: just started another kreen cycle.. [Re: electrolover] #2914214 02/20/13 11:04 PM
Doog Offline
What are you trying to accomplish?
Re: just started another kreen cycle.. [Re: electrolover] #2914224 02/20/13 11:11 PM
E
E
Get rid of varnish and clean ring pacs.
Pulling the vc is a pain, so before and afters of the internals are probably not going to happen and pulling the plugs is risky so compression tests are not going to happen either. So the only thing we have for reference is oil fill hole pics, mpg, and filter inspection.
Re: just started another kreen cycle.. [Re: electrolover] #2914226 02/20/13 11:17 PM
E
E
Heres the fill hole before. Its got some varnish on the phaser and timing cover as you can see.
Re: just started another kreen cycle.. [Re: electrolover] #2914313 02/21/13 05:18 AM
A
ARB1977 Offline
A
Doesn't look bad. With 160k I wouldn't worry about it. Thanks for sharing the pictures.
2015 Tacoma 4.0L 60K (as of 02/23/18)
AMSOIL SS 0W30 / Toyota filter
2018 CRV 1.5L (as of 05/11/18)
Factory fill / Honda filter
Re: just started another kreen cycle.. [Re: electrolover] #2914322 02/21/13 06:19 AM
Clevy Offline
My old 2v had chocolate come out for the first 15000 miles I had it. I was using Amsoil at the time. After those 3 oil changes I couldn't get the oil even black with 5000 mile(8000km) oil changes. That included about 30,15 pound bottles of nitrous run through it,dyno tuning and 5 test and tune nights as well as 3 street legal racing nights.
It it ain't broke.........
2006 Charger RT
Miles x 2 per oil filter
Re: just started another kreen cycle.. [Re: electrolover] #2914351 02/21/13 06:57 AM
E
E
Like I said im running four qts of kreen through this engine.
Re: just started another kreen cycle.. [Re: electrolover] #2926481 03/03/13 11:23 AM
E
E
1150 miles in. The oil level has dropped back to full and it no longer smells like kreen anymore. Here's a pick of the stick. Pretty clean. Added another 1/2 qt to he gas and oil.
Re: just started another kreen cycle.. [Re: electrolover] #2926489 03/03/13 11:34 AM
E
E
Todays fill hole pics
Re: just started another kreen cycle.. [Re: electrolover] #2932467 03/08/13 10:25 AM
T
Trajan Offline
T
Originally Posted By: electrolover
They don't have pics because it doesn't work. But that's not to the purpose here. They keep startng threads to get people talking about this garbage.
So where are they? The before pics?
Re: just started another kreen cycle.. [Re: electrolover] #2932469 03/08/13 10:29 AM
E
E
My before pics are at the top of the thread. The othe pics are after using kreen again. I will post more pics every time I add more kreen.
Why are you bringing stuff in from another thread? Troll!
Re: just started another kreen cycle.. [Re: electrolover] #2932658 03/08/13 02:17 PM
demarpaint Offline
I must have missed this thread, thanks for posting.
God Bless Our Troops
Re: just started another kreen cycle.. [Re: demarpaint] #2932841 03/08/13 04:53 PM
E
E
So hows your kreening goin?
