Originally Posted By: oldhp
Ford-Trucks.com
Ford Truck Enthusiasts Forums> Performance, Engines & Troubleshooting> Ford Inline Six, 200, 250, 4.9L / 300
Check out this site. Type in "how to adjust valves 1983 F-150"
Thanks to your link, I think that there are two styles used in this era and it looks like mine are indeed adjustable.
Yeah I think that's correct. If they are adjustable rockers once you have eliminated the lash turning the nut about one turn tight regardless of the cam/lifter position should be good.
Sorry I botched that up. If they are adjustable the cam/lifter position should be on the base circle when adjusting of course and if they're not adjustable then position doesn't usually matter. I'm not sure if '83 are adjustable or not but they might be.
Looks like '85 was the year they went non adjustable (pedestal like my beloved Windsors!)
So the procedure would be the same as doing any other stud-mount rocker:
1. Make sure the valve you are adjusting is on the back-side of the lobe. You do this by rotating the engine until the OTHER valve on the cylinder you are adjusting starts to crack open. This means you are on base circle.
2. Using a socket to rotate the nut, spin the pushrod between your thumb and finger while slowly tightening down the nut. As soon as you feel drag on the pushrod STOP. You have hit zero lash.
3. From zero-lash, go 1/2 a turn to set your pre-load.
Yup, that's typically what I'd do for any valve train that is adjustable, accept in this case, I believe Ford is calling for 1 additional turn after zero lash is achieved.
Originally Posted By: 229
They just torque down.
It looks like the heads that have a pedestal are the ones you torque down and the cylinder heads that have studs get adjusted, unless I've missed something?
