Originally Posted By: Trav
Originally Posted By: notech47
It's hard to make AC or defrost work with an air cooled rear engine anything...Were Corvairs offered with factory A/C?
Heat and defrost isn't the best that's true but A/C could care less where the compressor is mounted or if the engine is air cooled or not.
As long as the condenser has decent air flow the system will work as efficiently as with a front mounted engine, maybe even better as the condenser is not in front of a hot radiator.
No.
I have worked on them, and they run hotter with the AC.
Airflow is blocked, and under hood air is way hotter.
The plumbing will be longer though like a modern SUV with rear A/C.
