Lovin' the Etec!
by IndyFan. 12/15/18 06:10 AM
Air Impact Wrench
by BenZahel. 12/15/18 05:19 AM
Luber finer 750 bypass oil filter info
by BigRich954. 12/15/18 03:59 AM
Ford Pickup Front Wheel Bearings 2WD
by benjamming. 12/14/18 10:52 PM
GMC oil fill tube
by Redright9. 12/14/18 10:24 PM
Where do I buy Toto toilets? That has them!
by Vern_in_IL. 12/14/18 10:04 PM
Best filter cutter for the price?
by DONWATERS. 12/14/18 09:38 PM
5W-40 vs 10W-30 for a 2018 Audi A4
by jcr1293. 12/14/18 09:25 PM
Gave up on quadrajet electric choke today...
by leroyd92. 12/14/18 08:54 PM
2015 Odyssey - Which synthetic ATF?
by AngryScientist. 12/14/18 07:56 PM
Hyundai extended my warranty
by ernied. 12/14/18 07:33 PM
2016 Traverse 6350mi Schaeffers 9000 5W30
by chevman4life. 12/14/18 07:21 PM
Oil filter for Canadian winter
by Popsy. 12/14/18 06:11 PM
12-14-18 only! Irwin vise @ Menards. $99.99
by Kruse. 12/14/18 06:01 PM
10" Subwoofer - $6.52 Each
by Greg L. 12/14/18 05:31 PM
Finding 507.00 spec oil
by sloinker. 12/14/18 05:31 PM
New Tires for the Old Chevy!
by dogememe. 12/14/18 05:09 PM
NEKGuy, Deltafaatl, wsalopek, jcr1293, maxwellk
66684 Registered Users
86 registered members (53' Stude, 4WD, 64bawagon, AandPDan, Astro14, 3 invisible), 1,421 guests, and 41 spiders.
Topics295,097
Posts4,927,763
Members66,684
Most Online2,553
Oct 27th, 2018
Painting help needed #2672485
07/03/12 10:32 AM
07/03/12 10:32 AM
Washington, USA
usdart Offline OP
usdart  Offline OP
Washington, USA
I painted my Motorcycle gas tank and side covers and it looks real nice..now for the question;
Do I need to finish sand before I clear coat? If so, what grit and how does the shine come back? I am afraid to wet sand because it dulls the finish and I am not sure if the clear coat will revive it.
Which is the best product for clear coat to protect against fuel?
Rust Oleum states it is resistant, is that OK?
Thank you Mr Paint GURU in advance for the help
Re: Painting help needed [Re: usdart] #2672627
07/03/12 12:41 PM
07/03/12 12:41 PM
St. Louis, MO.
KB2008X Offline
KB2008X  Offline
St. Louis, MO.
Are you spraying from a can or a spray gun ?
What did you use for a base coat ?
What will you use for a clear coat ?
You don't have to sand before the clear coat, but in this case I would because of the time interval between coats. Sanding with a 1500-2000 grit will provide a fresh surface with some teeth for the clear coat to adhere to.
I'm self-taught, not a pro, and what I would do in this situation is to practice on an old hood or trunk lid.
Keith
04 Town Car 4.6 5w20 FL820S
92 Ram D150 3.9 10w30 MO-090
03 S-10 4.3 5w30 Puro L10111
above on TropArtic Synthetic Blend
10 Toyota Camry - undecided
Re: Painting help needed [Re: usdart] #2672680
07/03/12 01:41 PM
07/03/12 01:41 PM
Michigan
dwcopple Offline
dwcopple  Offline
Michigan
800 grit with soap and water and then alcohol wipe down and spray the clear. Finish wetsand with 1500+ grit paper, buff, and voila!
2017 RAM Big Horn 4x4 3.6L V6
2011 Chrysler 200 Limited 3.6L V6
Re: Painting help needed [Re: usdart] #2672734
07/03/12 02:29 PM
07/03/12 02:29 PM
Chicago Area
mechtech2 Offline
mechtech2  Offline
Chicago Area
I'd wet sand it with fine paper, then clear coat it.
The grit depends on how nice the finish presently is.
But 800-1000 is good.
BTW, soak the paper at least 1/2 hour in water before using it!
This is a great tip. It will cut smoother and not clog up, and the paper will last longer. Let the paper do the work - light pressure.
When all is said and done, do like dwcopple said and use 1,500 and then buff it. Even a hand buffing with polishing compound and a soft rag will work.
Don't have fine paper? Go buy a pack with assorted fine grits - it's not much $. And you won't need much.
Re: Painting help needed [Re: usdart] #2672747
07/03/12 02:37 PM
07/03/12 02:37 PM
North of Washington, DC
Newreet Offline
Newreet  Offline
Mute your speakers and check this out.
http://youtu.be/_qPJTTRWttQ
Re: Painting help needed [Re: KB2008X] #2672808
07/03/12 03:29 PM
07/03/12 03:29 PM
Washington, USA
usdart Offline OP
usdart  Offline OP
Washington, USA
Thanks for the help..if you would like to see it email me cause I don't know how to post a pic here.
[email protected]
Rattle can paint job and it was not easy to make it look decent. Took me 13 times of stripping, primer and paint to get it this way.
Re: Painting help needed [Re: usdart] #4657860
02/06/18 10:53 AM
02/06/18 10:53 AM
Washington, USA
usdart Offline OP
usdart  Offline OP
Washington, USA
After 13 times I finally got it. Never will I paint again! Doctor says my balance is off so I should not ride. Sold my bikes and now I go fishing instead.
