BTW, if you install the fuel filter so the fuel in flows to the part of the filter element that you can see, then you can see if the filter element has a build-up of dirt, and therefore can tell by looking at it if it requires replacment.
If you install the fuel filter so the fuel in flows to the inside of the filter element that you can not see, then you can not see if the filter element has a build-up of dirt, and therefore can not know when you have to replace it.
However think about how many hours your average vehicle clocks on a fuel filter before it requires replacement. Even though small engines use small filters, they also use a small amount of fuel.
