stangyellow
Thread starter
Hahaha! Yeah the B cam is pretty old now as far as cams go. However, if you hear it idle, it doesnt sound bad with increased compression of the s/c. But yes, its old... and not much lift. I was all about a Comp Cams unit, then was talked out of it by the engine builder. You come in with a list of mix matched heads, cams and they say "no, you want these". In a way Im glad because i have a rocketship for a light car, and didnt spend a ton doing it.
The engine was dyno tuned with I believe Diablo software. So it wasnt just thrown together and sent off. Its been "safely" tuned.
I would like to get to the 500rwhp mark but that takes $3k worth of good heads to get there. My oil system is tapped into the pan with a SQ trim. I have an oil pressure gauge, but not oil temp.
I think I'll look to see if I can find a 5w40 Pennzoil full syn. Thanks for the advice everyone.
