Barrett Jackson 2019 Pics
by Nick1994. 01/19/19 05:41 PM
What do y'all do with old car parts?
by qdeezie. 01/19/19 05:11 PM
Diagnosing catalytic converters.
by Tlhfirelion. 01/19/19 04:20 PM
Oil recommendations for GM Vortec 8100
by Dudemanmaximus. 01/19/19 04:14 PM
Leaf Spring Questions- Lots of Questions
by George7941. 01/19/19 04:02 PM
Am I being out of line?
by Chris142. 01/19/19 04:00 PM
Some good modern rock songs
by 53' Stude. 01/19/19 03:51 PM
06 Pathfinder O2 sensor voltage sensor 1
by Bluestream. 01/19/19 03:50 PM
Honda Blue Coolants
by redhat. 01/19/19 03:49 PM
Let's talk about some of the other NHL teams
by 53' Stude. 01/19/19 03:45 PM
coolants for 1965 imperial
by ted s. 01/19/19 03:35 PM
Where to get real Dexron III ?
by das_peikko. 01/19/19 02:40 PM
Dexcool + Prestone AMAM Mix
by George7941. 01/19/19 02:31 PM
Questions about Maverik gas
by MRtv. 01/19/19 01:25 PM
Anyone Taking Superfoods ?
by Warstud. 01/19/19 12:55 PM
Permatex High Tack (80062)
by TheLawnRanger. 01/19/19 12:29 PM
A little warm down in Oz.
by Snagglefoot. 01/19/19 12:03 PM
Supertech 6607 - 7300 miles - 2017 Legacy
by MrWideTires. 01/19/19 10:21 AM
ejmiller, _THOR_, Captmorgan2112, TreadMonster, Snachlift500
66978 Registered Users
99 registered members (28oz, 69Torino, A310, AdditiveOCD, 14 invisible), 1,919 guests, and 35 spiders.
Topics296,850
Posts4,960,129
Members66,978
Most Online2,688
Jan 19th, 2019
Page 4 of 6 1 3 4 5 6
Re: Just how dangerous is Lucas Oil Stabilizer? [Re: 45ACP] #2501316
01/21/12 01:49 PM
01/21/12 01:49 PM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
Originally Posted By: 45ACP
Originally Posted By: Hethaerto
Originally Posted By: ltslimjim
^Why not just run 1 grade higher and not dillute your additives with a simple oil thickener? It's actually better to not use the 'blank' standard LOS. Not sure if their 'synthetic' oil stabilizer has any additives in it, but either is way overpriced for simply being a way to thicken up a thinner oil. Just up your grade to a thicker oil and drop the LOS.
You guys say that adding half a qt of LOS dilutes the oil's aditives, but what about dudes that replace a quart of oil with MMO?
It does the same thing, just the other direction. It makes the oil thinner and displaces those additives and base oil with solvents.
Lucas isnt solvents though, its Group I snot.
Aside from the soap and straight-80wt enigma, i honestly think it "sticks" to the insides of the engine and "plugs" problem areas (good holes and bad) and i wonder if LOS engines "run hotter," so, maybe it does do something shrug
No, I'm saying MMO's effect on the oil is the opposite of LOS.
2018 RAM 1500 Big Horn EcoDiesel
2016 Grand Cherokee SRT
Re: Just how dangerous is Lucas Oil Stabilizer? [Re: dabble] #2501333
01/21/12 02:11 PM
01/21/12 02:11 PM
Saskatoon canada
Clevy Offline
Clevy  Offline
Saskatoon canada
Doesn't mmo have phosphorus in it. Isn't that an anti-wear agent. It may thin the oil some however it does have some additives to replace what it's thinning.
I'm sure I'm wrong though. Will wait on the peanut gallery experts to correct me
2006 Charger RT
Miles x 2 per oil filter
Re: Just how dangerous is Lucas Oil Stabilizer? [Re: Clevy] #2501352
01/21/12 02:37 PM
01/21/12 02:37 PM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
No, you are quite right, it does have some phosphorous, but not much else.
Re: Just how dangerous is Lucas Oil Stabilizer? [Re: dabble] #2501470
01/21/12 04:41 PM
01/21/12 04:41 PM
WatUpDoc
ltslimjim Offline
ltslimjim  Offline
WatUpDoc
The 'other' difference is use of MMO compared to LOS.
The former is temporary/for a specific purpose(winter use only or during an oil change or two/perhaps few hundred-1k miles prior to change for cleaning benefits).
The latter is a waste of overpaid oil thickener.
The only time I'd use it: Engine was on it's last leg and the car would make better compression with a thicker oil but nearly broke down/away from home just thicken up the oil to drive it safely home = Lucas Oil Stabilizer.
I'd be interested to see what a VOA of their 'synthetic' version has in it.
92 Civic Hatch (stolen frown RIP)
07 Honda Fit Sport (A/T) WELCOME thumbsup
Re: Just how dangerous is Lucas Oil Stabilizer? [Re: dabble] #2555675
03/03/12 03:04 PM
03/03/12 03:04 PM
Arkansas
Doc Holiday Offline
Doc Holiday  Offline
Arkansas
I've worked in the lubrication industry for 8 years now. I too would like to know if Lucas will hurt a newer engine. Some things I know for a fact about Lucas is it will slow oil burning in an old diesel big truck. It will quite a loud power steering pump and slow leaks. Also in industrial gear boxes that are over heating, Lucas will reduce operating temps. No other oil add I've seen will lower the temps. Not sure how it works, but does on the gear box
Re: Just how dangerous is Lucas Oil Stabilizer? [Re: dabble] #2559555
03/06/12 09:40 PM
03/06/12 09:40 PM
Central IA
Robenstein Offline
Robenstein  Offline
Central IA
Its magic....has to be Doc, since the VOA basically shows its just thick as heck Brightstock with not much of anything in it.
2011 Triumph Speedmaster
1986 Chevy Monte Carlo SS
1970 Chevy Nova
2006 Scion TC
Re: Just how dangerous is Lucas Oil Stabilizer? [Re: dabble] #2563817
03/10/12 09:51 PM
03/10/12 09:51 PM
Arkansas
Doc Holiday Offline
Doc Holiday  Offline
Arkansas
I'm not promoting it as I don't use it myself. I'm chicken. But I have seen this stuff lower the temps in industrial gear boxes. STP and all the other thick "honey" oils will not. So it has something in it that will reduce heat. That is a fact.
Re: Just how dangerous is Lucas Oil Stabilizer? [Re: Clevy] #2597057
04/11/12 07:39 PM
04/11/12 07:39 PM
Arkansas
Doc Holiday Offline
Doc Holiday  Offline
Arkansas
I use LOS in all of my vehicles. I can tell when it's not in the oil, and I can tell when I've added it. Usually half a quart of the petroleum-based does the trick.
My cars run stronger with LOS. Quicker acceleration, better bottom-end torque, ......this is all based upon just driving the cars.
I've never had a problem with LOS, nor have I ever known anyone personally that's had a problem with LOS.
I've tried LOADS of oil additives over the last twenty-four years, and I always go back to LOS.
I really have to ask. How does thicker oil do all of these things. Lucas oil stabilizer has no additives and is super thick. Adding this diluted a perfectly good additive package already in the oil and thickens it. Why not save a few bucks and just go up a grade in oil thickness. Then you don't dilute the additive package of the oil. This reminds me of guys who blend different oils thinking they are getting the best of both worlds when in reality they are weakening the additive packages.
Try gear oil. It's cheaper. Or a straight 90w
Ok as a lubricant salesman for years, I've sold a lot of this stuff. I'd never put it in an engine that has no problems. But I've seen it keep a "wore"out engine alive. Big rigs that burned a gallon a week went down to 1/2 a gallon a month. Also there is something more than just "think" oil here. That is proven in industrial gear oils. I've watched as customers have had problems with over heating gear boxes. They switched to full synthetic oils to no help. Then put Lucas HD Oil Stab and and watch the temp go down. This is fact proven by before and after temps. No more over heating.
Re: Just how dangerous is Lucas Oil Stabilizer? [Re: Doc Holiday] #2597063
04/11/12 07:45 PM
04/11/12 07:45 PM
Arkansas
Doc Holiday Offline
Doc Holiday  Offline
Arkansas
Like I've said before, in the same gear boxes the customer tried (buying from me) Mystik (Cid V ?-think oil), STP Oil Treat. and Motor Honey. None of those worked. I watched a show on Lucas once and they wouldn't disclose what the "secret" is but there is something there to take "out" heat. They said it was something simple....I just know from experience it works. Doesn't matter if you like it or not. Also we need some tests done with engines. Not some lab test as there is no sub. for real world conditions. As I said before I don't/won't use it unless my engine was about dead but there is something to it
Re: Just how dangerous is Lucas Oil Stabilizer? [Re: dabble] #2597104
04/11/12 08:28 PM
04/11/12 08:28 PM
OKC
Chevys_n_Hawgs Offline
OKC
****Lucas Shill Alert****
Re: Just how dangerous is Lucas Oil Stabilizer? [Re: dabble] #2597260
04/11/12 10:51 PM
04/11/12 10:51 PM
Northern California, USA
Loobed Offline
Loobed  Offline
I would try Lucas if my engine was ready to explode.
Engine: 2001 GM 5.3L LM7
Current Fill: Valvoline Synpower 5w-30 w/Pure-One PL25288 filter
I.M.N Oil Enthusiast
Re: Just how dangerous is Lucas Oil Stabilizer? [Re: dabble] #2597443
04/12/12 07:50 AM
04/12/12 07:50 AM
Dallas TX
MetalSlug Offline
MetalSlug  Offline
Dallas TX
their is no danger, their is million peoples on the road still using lucas ( god please give them the light ) and I never heard any one on internet say their engine is damage cause by using lucas.
NO FRAM OCOD " Orange Can Of DEATH �
03 SVT COBRA 10th anniversary Whipple 600whp M1 5w30 Wix 51372XP
01 Corvette ZO6 stock M1 5w30 / M1-107A
2016 NISSAN TITAN dealer OC daily drive
Re: Just how dangerous is Lucas Oil Stabilizer? [Re: dabble] #2597699
04/12/12 12:30 PM
04/12/12 12:30 PM
Transylvania, Romania, EU
tudorart Offline
tudorart  Offline
For some reason all Autozones and the like recommend it...from Chicago to Miami
Re: Just how dangerous is Lucas Oil Stabilizer? [Re: Loobed] #2600729
04/16/12 03:00 AM
04/16/12 03:00 AM
nm
bayfieldkid Offline
bayfieldkid  Offline
nm
I did use Lucas once. Had an chevy 350 that spun a bearing about 200 miles from house. Towing 24' T.T. at the time. Drained oil put two bottles in and topped it off with Castrol 20/50. It thumped like a disco all the way home. Have not used the product since then. I must say though if ya got a motor about to explode this might hold it together for a minute.
Re: Just how dangerous is Lucas Oil Stabilizer? [Re: dabble] #2601476
04/16/12 09:51 PM
04/16/12 09:51 PM
Iowegia - USA
MolaKule Offline
MolaKule  Offline
Iowegia - USA
Again, you have to ask yourself, what does it or what is it supposed to stabilize in a fully formulated oil?
Scars remind us of where we have been, but do not have to dictate where we are going.
