I have a 12 foot wooden dory that I wanted to power. I found a 1993 4 hp Johnson on Craig's List. It was the needed long shaft version and was used as an emergency backup on a sail boat. It has less than 2 hours of time on it. Score!
It's been sitting for the last 15 years. I'm going to rebuild the water pump, fuel pump, and carburetor. I'll also replace the fuel line and tank(it was beyond hope, stored with the vent open). Anything else I should check?
I picked up the Clymer shop manual. It says that the first 12 gallons should be mixed at 25:1. They say 10 hours of double oil for the injected models. The horse power is not specified, and 12 gallons through a 4 is a lot different than through a 40. Anybody have a 4.0 owner's manual that may clarify?
Ed
Ed
