Originally Posted By: S2500Dog
Thanks for all of the replies. I figured out the procedures and steps needed to complete the spark plugs replacement. This information will apply to the Nissan 1.4L, 1.6L and 1.8L I-4 engines.
1. Unbolt the plastic engine cover secured on top with two small bolts.
2. Remove the two plastic pins above the radiator that secure the air intake with a flathead driver.
3. Lift up air intake assembly and pull outward to remove.
4. Unscrew and lose the jubilee clips on the pipe attaching to throttle body assembly and remove the smaller hose as well.
5. Unclip the electrical connector located near the throttle body.
6. Remove the pipe and set aside near the air filter housing.
7. Unscrew the four bolts attached to the airflow management unit or throttle body.
8. Remove the assembly from the intake manifold and set aside.
9. Remove the five bolts attached to the intake manifold and please be careful and patient during this process to avoid losing bolts.
10. Remove the rubber hose from the back of the intake manifold located in the rear.
11. Remove the bolts from the bracket on the right side of the manifold.
12. Remove the gray bolt located where the airflow management unit is placed to release the intake manifold from the engine.
13. Slowly lift up the intake manifold and pull away toward you.
14. You will see four individual coils attached to each spark plug. Remove the bolt on each coil and pulled up and straight to remove the coil assembly. Make sure to memorize each individual coil location.
15. Use a deep 14mm socket and a long thin extension with ratchet to remove the iridium equipped spark plugs.
16. Install Nissan OEM Denso or NGK Iridium spark plugs and secure each individual coil with the bolt torqued to specifications. Hand-tightened spark plugs first and then torque 1/2 to 3/4 of a turn with ratchet. Replace the coil straight down and secured them with the bolt. No gapping is required on the spark plugs.
17. Reinstall the intake manifold back in place and torque all necessary bolts removed earlier to proper specifications. Reinstall the rubber hose located on the back of the intake manifold
18. Reinstall the airflow management unit with the four bolts removed earlier.
19. Reconnect the electrical connector and reinstall the pipe with the necessary clamps including the small rubber hose as well.
20. Reinstall the air intake assembly with the plastic pins secured above the radiator.
21. Reinstall the engine cover secured with two bolts on the top.
http://www.youtube.com/watch?v=HrhY-x5z8EU
The price of technology it seems. But they don't mention this in the smoke and mirrors show.
btw.
my car
1. pop hood
2. prop hood
3. remove plug wires
4. remove spark plugs
installation reverse of removal
Of course I don't have room to talk as my car isn't running all that great, but if this is the most trouble the car will give you, then you can call it a blessing.
btw, I like the 5 speed Versa hatchback. i would want one someday and see plenty of them around. On my last route, Hyundai Sonatas were the most popular. On my current route, Versas are.
