Originally Posted By: DriveHard
I drive an Audi A3 that has the normal high degree of negative camber in the rear wheels. I also have 17" rims with 225/45-17 tires. The combination results in rear tires that cup on the inside edge quite quickly. I usually rotate the tires every 5000 miles to fight this, but I got a little over 10,000 miles on the last rotation. As a result, the cupped tires that I have now rotated to the front produce a lot of road noise (a decent roar, and a lower speed almost grinding feel). Will this cupping wear away? Is there anything I can do?
"Cupping" is one of those terms which can mean completely different things to different people. Do you really mean "cupping":
...or do you actually mean heel/toe wear:
Also look here...
You can "diagnose" heel/toe wear by running your hand along the tread area in one direction of rotation and then the other. One direction it feels smooth, the other it catches your hand.
Heel/toe wear can happen for all kinds of reasons and German sports suspension cars seem to do it a far bit. The BMW E39 does it on the outside edges of the front tires no matter how it is aligned, unless there is a continuous tread pattern about 1" in from the edge. Take a look at the Toyo T1R tread pattern compared to the old T1S - the T1R's continuous band at this location specifically addresses this sort of wear.
H/T wear can also happen from simple acceleration and braking. My winter tires get this because the rears mostly "drive" and provide much less braking while the fronts are opposite. They will heel/toe wear across the entire face of the tire in opposing directions front/rear.
