Originally Posted By: Spockian1
Originally Posted By: Bluestream
I would be very interested in seeing those tests.
There are a couple of threads here in which responses to queries to Purolator have been posted, which break out the results for P1 for various micron sizes. The numbers were extremely impressive.
And also, there is another thread here, where a BITOG member queried Purolator about flow for a particular application. Purolator actually set up and ran to test and emailed him the results which shows flow at various differential pressures, which he published here.
I don't have the links handy. And the search function here is not exactly a joy. But you should be able to locate them.
Quote:
Also, you would agree, that as the filtration ability is increase the flow through the filter is decreased,
No. The total surface area of the filter media figure in, as well. P1 is known to have a very large surface area relative to other filters for the same application.
The total surface does have an effect on the flow rate, that goes without saying. My point was that it is not hard to make a filter media with less than 9 microns, and it would cost no more to make. You could make media with a 5 micron rating, but you would not get the flow, especially at -30 temps.
Local cab fleets uses the cheapest filter they can fine and get 500K+ out of their Crown Vics, so I don't think it makes much difference...
