Originally Posted By: 93Chewbacca
In the end, I am less concerned with what these vehicles were lubricated with from the factory (15 years ago), I am really just looking to select an optimal lubricant from what is available today.
Okay Mr Chewbacca, the optimal lubricant is one that flows but yet does not leak,
You have identified this,..
You have also identified the longevity that can be obtained from a lube of a more liquid nature,
There are a few that you can choose from, You know about the Rover Product, "one shot grease"
The Traction Motor gear grease, the snapper lawn mower #00 grease,
And of course the "Backwoodsgoop"
http://www.novak-adapt.com/knowledge/steering_knuckle_repair.htm
I must say MR Chewbacca your "One in a million" to properly identify this ,
What I refer to as a "Master of the Obvious", and that is simply knowing that the square plug on top of the knuckle is to add a lubricant of a liquid nature,
I read your other posts on "Mud" your on the right track, Be Strong do not let these "Black Propagandist" Brow beat you, talk you down,
Do not let the "Brainwashed" effect you, So far on the4x4network there are only 4 confirmed "Masters of the Obvious"
And keep in mind the pictures of the grease shown in the Joint by the Toyota tech, Rixxer is a grease thinned by gear oil,
Some what, or slightly or however he wants to spin it,
Appears to be a #1 grade to myself and others, which is OK, suitable, found in most CV joints,
Again the window of greases to choose from are #00 #0 #1
for this application, this is what the guys the build them and warranty them put in there, from production,
