JHZR2
Staff member
I know Ive posted about lifting cars, but this is about equipment for doing so. It kind of is a tool time issue, but also an automotive general topic.
Go into a parts store, wal mart, tractor supply, and youll see as many if not more bottle jacks than alligator type hydraulic lifting jacks. They are rated for more weight, 8, 12, 20 tons are common, but also have no angles or lever arms so I guess that is part of it.
They also make shorty ones, which are only 6" high. Interesting.
Obvious stability issues aside on some terrain, given their size, weight, able to be moved easily without rolling around, high lifting capacity, etc., is there a good case for owning and using a bottle jack to lift cars, if going say to a jackstand, etc?
Id think they could also be decent for doing tires, given their small size.
But nobody owns them. Measuring my cars, most would lift fine with a 6" shorty bottle jack (assuming the right jack point or way to spread the pressure of the pad). I dont know if the 10 5/8" max height would be a limitation for getting a wheel off the ground, but anyway... Does anyone use a bottle jack to lift their car? If so or not, why? Given shelf space Id think lots do, given pictures and recommendations I read, Id think nobody does.
Thanks!
Thanks!
