Which spec 229.51 oil would you use?
Originally Posted By: badnews
Syn power non ILSAC MST oil
that is not the run of the mill syn power you see on the US shelves JFYI
And I never said that you will see it "on the US shelves". I said:
Quote:
your local NAPA store should be able to order it for you
Well Pete we run into the it is easy to get and find oil problem again .
And again I state that is pure kaa kaa having to go to a auto parts store and order an oil , and pay a nuts price for it.
We as oil guys need to analyze what is out there, easy to get, and still will do the job for folks and not just repeat some dumb spec that an OEM has made to be elitist
You don't have to go there to order. You can just pick up the phone and ask them to order it. Then just go to the store to pick it up.
How much does it cost? Does it cost more than other Synpower grades?
Do you have any proof that it's a "dumb spec"? Do you know more than MB engineers do? Please share the knowledge... we would all like to know.
Sure
It is an ultra high performance diesel spec 0.08 and 0.06 below saps
:vs:
a super high performance diesel spec 1.00 saps
The difference is the mileage before an oil change
10,000 miles
vs
15,000 miles
and DPF change out which can be anything with any oil as it is measured by the
oil
type of driving
fuel used
Now rebut that with facts (and a source ) or admit I am right .
source
www.lubrizol.com/EuropeanEngineOils/E408.html
http://www.lubrizol.com/Products3column.aspx?id=34976&linkidentifier=id&itemid=34976
It is like saying you will only drink Bud Light - but will a Coors light really quench the thirst ?
Originally Posted By: gaiex
So the TD 5w40 will be thicker than the others all the temp range, right?
This could also let the fuel consuption rise a bit or what?
I noticed that the TD 5w40 produces more ashes (0,8) than the others, how this can afect performance and fuel consuption?
Sorry for so many questions, but till now I learned alot with your replys, Thanks
It (the TD 5W40)is a bit thicker than 0W40 but you run into +30 to 40C. in Portugal a lot more than -20C. As far as the slight difference in ash, it is still within MB229.51 specs and your DPF and catalysts will still last a very long time.
Charlie
Does it get -39 f In your country often ---- the pour point means little to most people . Even where I am at it don't even become a consideration till it is like -20 or more.
Source:
Fact 1: your Mercedes has a catalyst
Fact 2: catalysts are degraded by sulfur and phosphorus
Fact 3: 228.31 oil has up to 4000ppm S, up to 1200ppm P, 229.51 oil has up to 3000ppm S, up to 900ppm P.
I had intended to stay out of your ..."discussions"... but your errors are quite obvious and basic.
Charlie
NO OIL in the USA meets this spec and that is why it is nuts . ( Except Mobil ESP oil that can not be found except by special order and expense )
Not true. M1 ESP is sold at PepBoys. There is also Valvoline Synpower grade that meets this spec and your local NAPA store should be able to order it for you.
That is like saying I found a ruby once while mining gems in Arizona, come on lets be real
order oil
pay shipping
go to twenty parts stores
you got to be kidding
Source:
Charlie
Are you quatro pete ?
Your tirade of questionable facts
You have failed to show where any oil used will ruin a catalyst
all oils have SAPS in them it is just a degree
Please next time let pete respond for himself
source
This page only says that MB 228.5 spec is loosely based on ACEA E4. It makes no mention of MB 229.51 which is the subject of this thread.
229.51 is based on ACEA A3 B4 and C3. Compared to ACEA E4 in the article above, MB 229.51 spec is much superior in terms of soot thickening, wear prevention, sludge prevention, oxidative thickening and aftertreatment compatibility.
Well, drinking Listerine may also quench my thirst, if that were my only objective. But if I also want to make sure that I don't experience any side effects, I might stick to water instead.
source
Is Listerine a beer ?
See how we digress from fact to internet word smithing .
Shame shame shame
If you want to deal in facts stick with facts
order oil
pay shipping
You won't pay shipping and you'll go to one parts store.
The only downside is waiting for the next truck (usually weekly).
order oil
pay shipping
You don't pay shipping when you ask NAPA to get something in store for you.
Please, sell your MB-powered vehicle already and stop complaining.
order oil
pay shipping
Bob
I was told at advance auto
no oil orders
NAPA said ok but only if it was in their order book - it wasn't
You are fortunate to be able to do that not all are and that is why I am speaking up about it
Is Bud Light a motor oil?
No but Shell Rotella T6 is and that is what I propose for folks that need a Benz oil spec 229.51
when they can't get the 229.51 or 229.31 spec'd oil
Hey Badnews,
MB dealerships, Pepboys, Autozone should all be able to purchase Valvoline MST 5w-30/5w-40. It would not surprise me if the dealerships were cheapest.
In any case the Rotella T6 would probably work fine as well.
Why is Castrol TD 5w40 alot cheaper than Castrol 5w30? (also in other brands)
Just because of the lower ash numbers and a "long life" certification?
If 5w40 is a better oil and protects better why the 5w30 is good to run 30000km while the 5w40 is only good for 15000km?
Which 5W30? The low SAPS Edge 5W30 that is A3/B4/C3, or is it just an A3/B4?
If it is not a C3 oil, it has more TBN/alkalinity and can withstand acid buildup longer.
Charlie
Low SAPS Castrol edge 5w30 ACEA A3/B3, A3/B4, C3 and mobil 1 ESP 5w30 ACEA C2/C3, A3/B3/B4, both have lower TBN than the castrol TD 5w40 (but higher than 0w40), and are more expensives!
I'm confused!
PS: Castrol Edge TD 5w40 is also ACEA A3/B3, A3/B4, C3
