Originally Posted By: dnewton3
I hear a lot of talk about how the engines like the thicker oil.
But I suspect many are confusing what THEY like (as humans), versus what the engine performs best with (IOW, what it "likes").
UOAs show that the modular engines perform will with just about any decent oil. The 5w-20s seem to show good wear results, as does the 5w-30 and 5w-40. Perhaps we should consider that the engine design isn't that sensitive to oil grade? Certainly lighter grades are preferred for engines that have VVT; we know this.
I don't think the modular engines care much about what oil is in them (again, with the exception of VVT). I suspect that human interpretation of resultant audible esthetics (noise, or lack thereof) is what people are commenting on here, for the most part. That certainly is a part of the equation, but not all of it.
Perhaps the question should be thus:
If wear can be held constant, give a reasonable range of grades, would I be willing to trade some perception of noise for some loss of fuel economy?
Greenfordtruck, if you want to know how a thicker grade of oil will "protect" against wear, check out the UOAs, and/or run some tests for yourself. If your goal is noise reduction or fuel economy, choose accordingly, thicker or thinner.
This is actually kind of what I was getting at with my use of the term "likes".
The 5w40 made the engine the quietest.
The 5w20 had 1L/8,000Km IIRC consumption. The 5w40 did not.
The 0w40 yields the same gas mileage as the 5w20 in my truck, dampens noise to almost the same level as the 5w40, but provided vastly superior winter starting and no consumption. For our two vehicles, it appears to be the "best" choice of the oils I've tried.
