Hey guys I have posted a few threads on this site and through trial and error I have gotten great advice, but nothing has fixed the problem yet. About 6 months ago my check engine light came on. I scanned the codes and got a P0304 Misfire Cylinder #4 Code. I since then have changed many parts and attempted to clear the MIL and Code but it has returned. I have gone over kill with the amount of parts I changed.
The parts I have already changed are: Oil & Filter, Spark plugs, Wires, Coil Pack, Valve cover gasket & spark plug tube seals, Fuel Injectors, Fuel Rail, Fuel Rail Wiring harness(injector power), MAP Sensor for intake Manifold, throttle position sensor, EGR & EGR diaphram for vaccuum & more that I cannot remember off of the top of my head.
I still have the check engine MIL light lit up with the code P0304. At Idle it blinks, While driving it is steady unless I am driving at high speeds. I feel like I have more power, I do not have the stumble when I accelerate after changing the EGR. However, after driving I do smell a fuel odor from the motor and I do have white smoke from the exhaust upon startup for about 45 Seconds to a minute then blows normal.
People were telling me, Could be the cars computer or even a injector driver? Anyone with any advice or anyone that has the same problem please help me out. I have state inspection coming up soon and I cant pass with this light. I put so much time, blood, sweat and tears into this car because it belonged to my father in law that passed away and he left it to me, so it is kind of a priority to keep it running. If I have to go to a mechanic I will I just dont want to bring it if it is a simple fix.
Thanks Guys.
Thanks Guys.
