Originally Posted By: addyguy
Originally Posted By: ARCOgraphite
Originally Posted By: bepperb
ARCO claims to have had a 2azfe "die" on him, but in reality some of the valves were noisy and he chose not to adjust them himself because it would require removing the cam temporarily, which (while not difficult to a tech making minimum wage) was more effort than he had in him. IIRC also the water pump leaked, but that's obviously not oil related.
Thats DOHC, front cover , VVTI system, all front accessories, cam box, chains tensioners, a whole day 600 dollar job. PLus engine was burning oil, excessive piston slap, low on fuel mileage. Engine was PERFECT before a couple rounds of INFERIOR GF-4 garbage. Also lost 2 suzukis early but saved a mitsubishi 3.0L buy going to 10w-40 with 3000miles OCIs. I have NO doubt anymore that GF-4 oil and E10 combo is killing engines.
I know you've had your 'experiences' that guide your actions, but I really wish you'd stop posting this untrue information.
IF this was true, millions of engines everyday would be quitting on the raods and being hauled off to junkyards. Instead, vehicles now last longer than they ever had.
You abuse your vehicles on a daily basis, and that contributes to low engine life - that's all there is to it, Arco. Really.
+1 Something is going on with his vehicles, or the poor guy has about the worst luck going!
To the OP, use 5w30. If the engine was back spec'd to 5W20 and you'd like to give it a try it won't hurt a thing.
