I tend to believe that oil consumption is normal, not that zero consumption isn't possible or regularly "observed", but oil loss can come from many places such as the PCV valve, bouts of high rpm, high heat driving etc and should be accepted. I will consider that in the OCI's that I have had with this car, including the version with no make up oil (my first UOA), the oil level never fell below the operating range and was good enough to continue driving when the OLM said to. I would consider that a success.
Additionally, based on observations on this UOA forum, in an extended drain situation some consumption, with monitoring and make up, can be beneficial from a TBN standpoint, however I am not sure on the effects consumption has on viscosity.
Ideally, I would like my engine to wear in 13,000 light duty/normal? miles the same as a traditional 3k severe service OCI. Im not sure if that is possible, but the UOAs here seem to tell me that the engine is doing well, and I should expect to not have internal engine problems before my car is paid for.
