OVERKILL
$100 Site Donor 2021
dkryan:
Click Start -> Run -> CMD
In the command prompt that opens, what does it show for your IP address? Is it a 192.168.x.x address? A 10.0.0.x address or is it a public IP? If it's a public IP, then your cable modem is just that, JUST a modem. If, on the other hand, you have a private IP (the above two examples are the most common; there are more) then your modem ALSO has a router/gateway as part of the device and you don't need anything else.
If you have a public IP, I suggest something like the ASUS WL-520GU router. Great little device. Just disable the wireless if you aren't going to use it.
