Hi, guys... here's my first UOA on this build; I wish I'd found this site years ago. This is a 1998 Trans Am with a forged/dished piston lower compression LS6 motor from A&A Corvette. This motor has about 10k miles on it now, roughly 8k of that is with a T67 front mount turbo. This turbo setup utilizes the engine oil for lubrication. I run at about 11 psi on the street and use boost-actuated progressive methanol sprayed about 10" in front of the throttle body. There's also a large front-mount intercooler on the car. Tuning is custom 2bar speed-density. Coolant is DI water with water-wetter. Dino oil was used to break-in the setup prior to going with the RP. So here's the Blackstone comments/report:
"Universal averages show typical wear levels from this type of engine (stock) after about 4500 miles on the oil. High metals are coming from a combination of wear-in and the methanol-injected turbo. Copper is very high; it may indicate a problem at the turbo (or another bronze part). Heat damage can be seen in
zinc and phosphorus levels. Silicon is likely from sealers and lubes applied at assembly. 1.0% fuel was found, but this is not a problem level. We aren't sure if this engine is simply going to make a lot of metal due to the methanol, or if there's a problem."
Aluminum 19
Chromium 6
Iron 85
Copper 228
Lead 16
Tin 0
Molybdenum 123
Nickel 3
Manganese 2
Silver 0
Titanium 6
Potassium 3
Boron 5
Silicon 74
Sodium 12
Calcium 3110
Magnesium 109
Phosphorus 1072
Zinc 1976
Barium 2
SUS Viscosity @ 210F 79.5
cST Viscosity @ 100C 15.41
Flashpoint in F 365
Fuel% 1.0
Antifreeze% 0
Water% 0
Insolubles% 0.3
I look forward to your opinions on this UOA. Thanks!
Aluminum 19
Chromium 6
Iron 85
Copper 228
Lead 16
Tin 0
Molybdenum 123
Nickel 3
Manganese 2
Silver 0
Titanium 6
Potassium 3
Boron 5
Silicon 74
Sodium 12
Calcium 3110
Magnesium 109
Phosphorus 1072
Zinc 1976
Barium 2
Flashpoint in F 365
Fuel% 1.0
Antifreeze% 0
Water% 0
Insolubles% 0.3
