If you completely saturate/max out your available download/upload bandwidth, your bufferbloat will go up. So what I did was reduced max dl/upload speed a bit on the router to leave some breathing room for control traffic and such. For example, if your max is 24 Mbps upload now, set it to about 22 Mbps and see what happens.
Now, if you have a big fat connection to begin with, chances of you saturating it with regular traffic are probably very small, so it may be nothing to worry about. The dslreport test just show what happens when you completely max it out.
To identify good vs bad bufferbloat the speed test applies grades as follows. ms means milliseconds, and refers to an increase in a measure of round trip delay when your connection is fully utilised.
Less than 5ms (average of down bloat and up bloat) - A+
Less than 30ms - A
Less than 60ms - B
Less than 200ms - C
Less than 400ms - D
400ms+ - F
(there is no "E" grade).
To recap: to get an "A+", ( average(uplift during upload) + average(uplift during download) ) / 2 must be less than 5ms.
Currently the majority of people grade "C" or worse. This is because most equipment and software currently in use has bufferbloat issues.
Tests done on PC via Chrome browser with a Realtek GbE onboard NIC.
Quattro Pete also noted that enabling QoS decreased bufferbloat where I have that option disabled because it's not needed in higher speed connections.
That's a bit of an over simplification, and one he has since expounded upon in the post above. Bufferbloat becomes less apparent on higher speed links because the ability to achieve saturation is more difficult.
Your link, being not only asymmetrical but significantly so, means that saturating your upstream side is quite easy to do. Though I assume you don't pass a lot of upstream traffic in typical use unless you serve up torrents without a bandwidth restriction setting.
Did you note my mention of different results with different browsers? I thought it interesting the difference between IE and Chrome.
FYI, in my case, I am not seeing much (if any) difference between Chrome and IE, possibly because my speeds aren't high enough. This is from IE. The previously posted one was from Chrome.
