i was wondering if anyone has tried XenTx and what you thought about it. i read the posts about it that was made sometime back,but haven't noticed anything recent.thanks.
There is info about it here.quote:
Originally posted by bigwillie:
what is xentx supposed to do anyway. I've never heard anything about it or seen any commercials on tv.
What was the percentage gain in mpg for her vehicle? What was her before and after mileage? I'll do the math.quote:
Originally posted by FowVay:
After I had played with the stuff enough, I just poured the remaining eight ounces into my wifes car engine and threw the bottle away. Several weeks later my wife commented that she was getting about 2 extra MPG's over the course of two fill-ups according to the cars computer. She didn't know that I had poured the stuff into her engine.
Personally, I'd buy the product if it were priced right (less than $9). At the $17.99 price that my local K-mart charges I will pass on the purchase.
I figured the break even point for a first oil interval at 2/3 of a bottle of Xentx for your wifes car at just under 2000 miles at 2.25/gal. Followup intervals at 1/3 bottle the breakeven point should be just under 1000 miles. With a 3k oil change interval she should be pocketing an additional $13.30 per oil change in fuel savings. Not wanting to purchase it at 19.95 would cost you $4.43 every 1k miles versus purchasing it. Your wifes mileage should creep up slowly as she continues to use it until the gains level off.quote:
Her before mileage was normally in the 25 mpg range and the mileage went up to 27. So I guess that works out to a 8% gain.
quote:
Originally posted by wulimaster:
[qb]
I have been using XenTx for a little over a year now and am running it in 4 vehicles. The vehicle with the most miles on the Xentx is getting about 9% better highway mileage and less of an increase around town mileage. That vehicle is running Amsoil 0w30. The diesel vehicle has only about 5000 miles on it in the last year and I havn't posted a followup test to see what the current mileage is. Perhaps I will go out and perform another test run today if there is little to no wind. I recently put some in a small dodge dakota pickup truck at half a tank down and the mileage was up 5% for that tank and 10% for the following tank. I don't have followup readings yet and may not as the drive has changed for that vehicle. I put a little in a newer honda civic (my mother inlaw) but since she doesn't track fuel economy I will never know. Usually the results are not that quick and require at least a full oil change interval to see results. All the cars I have control over are running Amsoil S3000 or S2000 oil and gains are above that baseline.
Again. What was the before and after mpg?Have you done any UOAs? I would really like to see what the XenTx does to your oil and how it affects wear so I can determine if I want to use it or not.
I have seen many, many UOA of fleet vehicles and the oil analysis usually show a reduction of certain wear metals and no change to the rest. Iron is reduced as is soot in diesels. TBN actually ends up slightly higher or no change compaired to baseline.quote:
/QUOTE]Have you done any UOAs? I would really like to see what the XenTx does to your oil and how it affects wear so I can determine if I want to use it or not.
