Wix XP efficiency
Originally Posted By: irv
Price aside, could that info, based on their findings, not cause some lawsuits once shared, especially if the results came back negative or less than stellar?
If you mean WIX trying to sue because the test came back worse than their unpublished spec, then I think all that WIX could do is dispute the SwRI results with their own ... which they won't even give the public anyway.
Originally Posted By: ZeeOSix
Originally Posted By: dnewton3
What we all need to realize is that, to my knowledge, there is no current, relevant SAE study regarding filtration.
Most all of our information for discussion comes from decades old data (the GM filter study; the bus study). Those two in particular are often referenced as the gold standards, but one is an ALT that GROSSLY DISTORTS REALITY, and the other was done on 2-stroke DD engines that were notorious for soot generation and sub-standard air filtration.
My point in all this is that there's no relevant data that directly proves the points we discuss.
In all our discussions about the SAE Bus Study you regarded that one as having pretty good validity, as I do. IMO, it doesn't really matter if those engines were 2-stroke DD engines or not. Fact is, their study showed a clear correlation between oil filter efficiency and Fe levels/engine wear.
What this all boils down to is that there certainly is an effect on engine wear with better filtration, but on well maintained vehicles you're not going to see an engine "blow-up" or "totally wear out" beyond FSM specs before the car rusts away or other issues cause it's total demise. I've never eluded otherwise, only have always said higher efficiency oil filters will help keep engine wear down compared to a much less efficient filter, just as the bus study showed.
Personally I use high efficiency oil filters because I don't care about saving $3 on an oil filter (easier to save way more on other purchases in life), and because having an efficient oil filter to complete the "anti-wear triangle" (oil, air filter & oil filter) is worth doing. And I really don't care if someone uses a low efficiency oil filter, it's their car and money. But I do care that some people (not you dnewton) will argue and say that cleaner oil doesn't mean less engine wear just because they think they've proven otherwise on their own accord with no official data of any sort to back-up their misconceived claim.
Zee and I agree on this, but for those who doubt, let me do this:
I guess I need to make an absurd analogy to put this in perspective ...
Let's say you want to make sure you don't get any bears around your home. And so you think "I'll get a dog; he'll bark and scare the bears away." You can get a small yappy dog, or a large dog. In fact, there are some hounds that are specific to certain regions that actually are bred for this. But you cannot decide if the extra money spent on the higher efficiency animal (small dog vs big dog) is worth it. But the issue you're overlooking is the rate of bear occurrence in your area. If you live in downtown Indianapolis, there are no bears here at all. So it really does not matter how much money you spend on a more efficient dog, because the occurrence rate of the bears is pretty much non-existent. Even if there was a bear in Indianapolis, downtown Indy is a big place, and the likelihood that the bear will camp out in your lawn is very small, and the likelihood he'll remain after any dog barks at him is practically zero.
My point is this: the efficiency of the product can only have a tangible effect if the occurrence rate of the objectionable offender is reasonably present. Rare occurrences of offense are not greatly manipulated by efficiency delta in competing choices.
Now return to the oil filter discussion. Trying to show a real-world effect between two normal off-the-shelf filters is insane, because the particulate loading in a modern, well designed and made, fuel-injected engines with a good air filter system is MOOT, and I mean COMPETELY AND TOTALLY USELESS CONVERSATION. The bus study is valid, and I do like most of what it shows, but it does not relate to our cars or trucks much because the old buses they ran were DIRTY running, and had poor air filtration. Had the air filters been better, there would be far less wear overall. Had the engines run clean (not dirty 2-stroke diesels), there'd be far less contamination in the crankcase. The reason the bus study showed a large disparity is because there was a LOT for the lube filters to clean up. But today's vehicles do not present that same operating environment to FF filters today.
SAE study 952557 from Donaldson shows us that TOTAL WEAR is what we need to look at. Wear contributors are not just lube filter related, but also air intake, soot generation, fuel related, corrosive, etc. The vast majority of potential wear comes from ambient air contamination. Let me repeat that ... THE VAST MAJORITY OF POTENTIAL WEAR COMES FROM AMBIENT AIR CONTAMINATION. The greatest disparity of wear induction comes form the air intake tract. You can DOUBLE the wear of your engine by changing air filters too often; especially in the first 30% of the filter's lifecycle. Way down the list in terms of effect is the topic of oil filtration efficiency. The study does show the "better" filtration has a positive effect, but again, it has to use a huge magnitude of disparity to illuminate this effect. IOW, the difference in wear protection between a 20um and 10um rated filter is tangible, but that's not what we are discussing here. We're discussing the differences between filters that are 99% or 95% or 90% all at 20um. Folks, you're not going to see a significant effect by pitting a 95% filter against a 99% filter; the disparity is just too small in terms of tangible effect. And not one study I have ever seen actually takes into account "normal variation" (standard deviation). Whereas the "average" (mean) effect might be a few particles, the typical everyday use of any equipment dwarfs the sounds of filtration disparity. It's like trying to hear your phone ring in rock-concert arena; you cannot distinguish the differences of a few decibels difference in ringer volume control of the phone during a 100 decibel ode to Bon Jovi. There is so little contamination in a sump system today that the minor difference in filtration have ZERO practical effect in overall wear.
Examples:
- You first run a series of UOAs and PCs using a 95% filter (say a Wix/NG). The average Fe wear rate at 5k miles might be 2.53ppm/1k miles. And the variation of that might be 2ppm. Hence, your "normal" magnitude of expected wear over several successive UOAs might be anywhere from .53 to 4.53ppm.
- Now you swap to a 99% filter (TG), and run the tests all over again. Now you get an average wear rate of 2.48ppm/1k miles. Your variation is still around 1.8ppm. Hence your range is now .58-4.38ppm. Your mean shift was .05ppm, but your range is still almost 4ppm!
You are either ignorant or arrogant if you think you can discern real wear in a tangible manner when your standard deviation is far greater than your mean shift! 95% of your wear rate overlaps between the filter choices! And because we only care about wear increases (that's what' detrimental), you can cut that 5% disparity in half; only 2.5% of wear reduction might be tangible on the upper end of wear rates.
At some point, oil filtration is "good enough" to make wear a non-issue in terms of sump cleanliness. Having a clinically clean sump might make your engine last infinitely, but there's no practical return on the investment. The difference in wear rates might accumulate to perhaps a 8k mile difference after going 350k miles! In other words, if you had used the premium filter, you engine may have the experience of 350k miles, but if you had used the lessor filter, it may experience the equivalent of 358k miles of wear. And for what? Spending 2x the money on filtration ($12 filter vs a $6 filter) does NOT double the life expectancy of your engine. The disparity in lifecycle improvement is so freakin' small that's practically impossible to measure in REAL LIFE. I cannot assure you these values are 100% correct; they are examples. But the meaningful point to take away is that there is not a equivocal linear relationship between filter expenditures and wear reduction. It's parabolic. And the disparity which we discuss is so stupidly small that we cannot even accurately measure it. ALL THE FILTER STUDIES I'VE EVER READ use a large disparity between pore size, so that the disparity becomes clear in data. But our choices today (80% vs 90% vs 95% vs 99%) do NOT show such disparity in wear control. Ever wonder why it is that a Honda or Toyota engine running OEM filters lasts so long, despite the generally loose filters they employ? Did it ever occur to you that oil filters are important only to a level of "XY"%, and then they are usurped by other contolling factors like air filtration and TCB?????
Spending $10 on a FU over $6 for a TG will not get you 65% less wear for the 65% more money you spent; they are both 99% efficient and have way more capacity than you'll need. Even a Wix at 95% is more than your engine will ever need. Even a EG at 95% for $4 will give your engine all the protection it ever needs. Spending more does not equate to less wear in a tangible, real sense.
Sure - lab tests can show a disparity in filtration effect on the lube; that is a direct relationship. But it can only imply an effect on the overall lifespan of the equipment, because once lube filtration is "good enough", improvements in filtration have a diminishing rate of return on a very deescalating scale. This is true because of three things:
1) the oil filter is secondary to a good air filter and ambient dust conditions
2) there is a law of diminishing return in terms filtration in modern, clean running, low contamination engines
3) the TCB effect runs in concert with the OCI duration, thereby affect wear rates
I triple-dog-dare anyone to find an oil filter study that takes into account "normal" total wear variation of a typical OCI, and then proves that minor filtration differences matter. Go on - try to find one. I'm waiting ..............
I agree, and always have that there won't be any relatively huge difference in wear between 95% vs 99% at 20u filters. That's why I say many times in these discussions that any filter that's 95% at 20u or better is something I'd run, and have many times. I stopped using Toyota OEM on my Tacoma because efficiency info showed they were not efficient enough for my taste.
But personally I'd want a super dog that can handle any bear that happens to wander into the yard, not some little yapper dog that's gonna become a bear snack.
Yet millions of Toyota’s ran for untold hundreds of thousands of miles on their “inefficient “ OEM oil filters.
Does a vehicle need a 99% efficient oil filter? It sounds great but we have not heard of large numbers of engine failures attributed to inefficient filters nor even lubrication. Again, a big mountain is being made on brand fanaticism vs real world facts.
I'm not disputing they won't "run forever" on lower efficiency oil filters - but can someone prove there isn't more wear on the engine at 300K miles from using lower efficiency oil filters for the life of that engine? Some people like high efficiency oil filters, some don't. Each side has their arguments on why they use what they use. Look at the by-pass filter guys ... they are a whole magnitude more nuts about filtration than the high efficiency spin-on guys.
The high efficiency guys use data from technical studies showing that more efficient oil filter save engine wear. The low efficiency guys say something like "How many dead vehicles do you see on the side of the road because of low efficiency oil filters?"
As always, if someone wants to run a high efficiency oil filter or a low efficiency oil filter based on what they conclude is their reasons why, then everything is good. People can read information and make up their own mind ... always been that way here.
So yeah, a vehicle "needs" a 99% efficient oil filter if the guy buying and using that filter wants to use it based on his conclusions to why he wants to use it ... no different than the guy who buys a low efficiency oil filter to use for the reasons he believes are important to him.
I'm sticking with my Wix XPs. I'm not buying all this speculation that it's a lower efficiency filter than the standard Wix, nor it's worse than the Fram Ultras. Wix themselves had the Beta numbers posted on the website as B2=20 for the Wix XPs. I know a lot of people have mentioned "that only means 50% of particles 20 microns in side, because that's Wix's format." That is clearly wrong, as it doesn't look anything similar to the Beta ratio formats they report for their standard filters.
For example. The Beta Ratio listed for the Wix 51042 is (was) listed as 2/20=6/20. This number is represented as 2/20=x/y, or . Capture Efficiency (percent) = 1 - 1/z (where z is replaced by the 2 and then the 20), therefore this number could be written as 50%/95%, which is used to provide particle capture data for a filter. The 2 corresponds to the x will be caught 50% (1/2 pass through) of the time, and the 20 (1/20 or .05 pass thorugh) corresponds to the y, indicating that a particle of size y will be caught 95% of the time. By applying this to the Wix 51042, we now can see that 2/20=6/20 means that the filter captures a 6 micron particle 50% of the time, and it captures a 20 micron particle 95% of the time. Or, as as formatted for how they described the Wix XP efficiency B6=2 and B20=20.
Yes, they changed the way the are reporting the Beta ratio, and they do not include the specs for different particle sizes, but the B2=20 (or 95% of particles 2 microns in size) is the way the format that the industry reports efficiency numbers. Many people have reported white papers indicating that. Here is another reference https://www.youtube.com/watch?v=aiLhfAFhkvs.
No, Wix won't have any marketing trolls on this forum that will concur with this, but I will believe it until proven otherwise.
Sorry to say, but you're all wrong about your interpretation of the WIX beta ratio format. It's been discussed many times over the last 10 years in this forum (you've been here that long), and even verified by phone calls to WIX that B2=20 really means 50% at 20 microns.
No passenget car oil filter is 95% at 2 microns efficiency. If there is one, sign me up.
That should give you a clue that you're seeing it wrong. WIX's beta format is backwards from the way most industry does it, and that's been proven many times over the years when this subject always seems to pop up.
I know it has been discussed over and over, and you refuse to believe the claims that the XP is a good filter. Everywhere on this forum that the 50% @20 micron rating is claimed as the truth, your name seems to come up as the point of reference. Wix is for one thing doing a really bad job marketing. I have also seen claims that when contacted, Wix did say 95% at 2 microns was the correct number, and I have also seen the other way around. There is no way 50% at 20 microns is correct if Fram is specifying 99% at 16 microns. If Fram does one thing really well, it's marketing. Examining the build quality of the filters, I am choosing one over another.
I hope some people on this forum have an open mind about the opinions of others research, and realize there are people on this forum that work for individual manufacturers of some filters (many claiming so).
It is a "good" filter, but not a "great" filter IMO, and many othets here who like high efficiency filters have said the same. It is what it is, and the 50% @ 20u has been proven valid from WIX themselves by many members here. What other truth do you need? Buy 3 XPs and send them down to the SwRI with $4500 and have them ran through ISO 4548-12 to get your own validation since you don't believe anyone here or even believe WIX.
Wix is for one thing doing a really bad job marketing. I have also seen claims that when contacted, Wix did say 95% at 2 microns was the correct number, and I have also seen the other way around.[\quote]
WIX has never said anywhere that the XP is 95% @ 2u. If that was ever validatrd to be true it would be talked about all the time. Burden of proof on that claim is on you, and dig up something official, not your misinterpretation of the WIX beta ratio as "proif".
99% @ 16u isn't hard to believe. Other high efficiency filters are about the same, in fact the old yellow PureOne was that good or better. Purolator gave efficiency numbets down to 5u and it was posted in many threads. Like said, you've been here over 10 years so why haven't you seen all this stuff?
Most people here operate on facts, not opinions. Every piece of data anyone here has found about the XP directly from WIX is that it's really 50% @ 20u. You think WIX wouldn't say otherwise if it's not true. They can't legally say it's better than it is, because that would be false advertising open to legal action.
Well-the last time somebody asked Wix about the XP's efficiency, they got NO ANSWER AT ALL! I have no problem using Wix-but the fact they are now owned by Mann & Hummel, who have LIED to me PERSONALLY about their products, when they bothered to respond at all, leads me to have a lot of basic distrust in anything the say, market,or manufacture in the US. I have, will, and do use Wix-but they will be assimilated into the M&H way of doing things eventually. Their customer service department is well on their way!
I love that you keep talking about it being a "fact" that Fram's filters are 99% efficient at 16 microns when they pulled that from the website. They also have changed that number on the filters of the years as I have noted. Back when they release the Ultras, they claimed 97% efficiency, where the TGs were 99%. Maybe they just kept testing filters over and over, and happened to find 4 filter models that were much more efficient than others, and revised their numbers using those as the reference models (99% at 16 microns based on filters...). That alone still doesn't mean the Ultras are any better than any other filter out there. You need to realize that "facts" in this area are not truly "facts". They are claims that a manufacturer is making that they could back up somehow if someone attempted to take them to court. Ever hear about cigarettes being good for you?
Let's break down Fram's claims shall we:
"A 2-ply synthetic, metal screen reinforced media provides 99%+ filtration efficiency.†
Traps and holds more than double the dirt of typical retail brand oil filters.*"
Then for the good stuff (the fine print):
"†Fram Group testing of average filter efficiency of PH8A, 3387A, and 4967 or equivalent FRAM TG or EG models under ISO 4548-12 for particles greater than 20 microns"
Note that this tag only has to do with the first bullet above, and only speaks to microns "greater than 20 microns". Take 20 80 micron particles, 20 60 micron particles, and 20 30 micron particles. If they can filter out 99% of all those particles, they technically meet this claim.
Then the fine print for the second bullet:
"*Fram Group mulitpass testing of representative sampling of average filter capacity of comparable competitive retail products based on ISO4548-12 for XG8A and XG3387A."
Holy [censored]. It traps "more dirt than a typical retail brand oil filter" according to ISO testing" That's amazing!!!!!!!!
Enjoy the Fram Coolaid (Just don't mix up Prestone as Fram's Coolaid brand
When I’m wrong on something I’ll admit to it. Well, I’m admitting to it. I just contacted WIX. I talked with their technical department. B2=20 is in fact 50% at 20 microns. The magic number WIX is targeting is 35 microns. The XP is specifically for extended oil changes using synthetic oils. They informed me that WIX is geared more toward meeting OEM specifications. Personally, I don’t do extended oil changes and I may never use the XP. If I catch a special including 5qt. of synthetic oil, I just might go for it. I invite anyone to call and verify what I’m saying. 704-864-6748. So Zee06, there it is.
I never said the 99% @ 16u was a fact. Someone posted that (not me), and I just said it wouldn't be that hard to believe. Anyone who's knowlegable about oil filters and understands what the efficiency vs particle size curve looks like fot a high efficiency full synthetic filter could see that. You might wantvto studyvupvon that some.
Fram publicly states their claims with an ISO 4548-12 test spec. They wouldn't make the claims If they couldn't defend it in court. WIX now publishes absolutely nothing to the public about their filter efficiency. They won't even tell you on the phone, snd make some kame excuss thay it's "proprietary information" ... very nin transparent, for obvious reasons.
You should throw in another $4500 and send 3 Ultras over with those 3 XPs to SwRI and see how that goes. Maybe you'd have enough data to take Fram to court for false advertising.
You seem to come across as a very uninformed WIX fanboy,(and a Fram hater) or else maybe a secret WIX "company rep" that has been asked by corporate to go try to spread false information to help confuse people. A real "company rep" should know the facts (especially how they use beta ratio format), so scratch that last part.
Thank you Mparr, I appreciate the honesty. Anyone can call WIX and hear it themselves if they don't believe Mparr.
You are welcome. I do believe it is a good filter for what it is designed for. With more people doing extended oil changes, it will be just fine. From the numbers it is very close to or better than OEM specs with the advantages of running longer oil change intervals.My guess is WIX wants good flow across the media.
There would be no way I could win a legal argument with Fram regarding their claims. Stating that they test to the ISO 4548-12 spec with very loose claims (99% of particles "greater than" 20 microns) would be impossible to disprove. Heck, I can't disprove their metal backer to the filter would not meet that specification. This is my point to all the Fram Ultra fanboys out there. READ BETWEEN THE LINES. I used to read this forum a lot, and everybody was all about hating on Fram. The tone has completely changed, and I am of the opinion that this is due to anything other than Fram improving their filters.
Then you look at Purolator. They rate their efficiency numbers as percentages of "Dirt Removal Power (Trademark)". What the [Censored] is that about?
If the Wix number of 50% efficiency at 20 microns or greater is true, kudos to them for actually publishing numbers that cannot be contested. That is a number that can be disproven if not accurate.
I like Wix filters alot. I typically like OEM filters too, but I have some concerns on the Motorcraft filters due to well documented tearing on some Purolator manufactured filters. I found the Wix XP to be a solution I can depend on for the extended 1 year/ 10K mile intervals Ford recommends without the filter either failing or losing filtration power.
Mparr, so did they give you the efficiency number for the XP (there seem to be using 99% @ xx microns these days), or just tell you it's "propriatary information" ir no info at all like they've told people who have called them lately were told.
