Originally Posted By: LoneRanger
For some time now, my regular dentist has been strongly encouraging me to go to an oral surgeon and have my wisdom teeth pulled. The wisdom teeth are still below the gum line, but according to x-rays, they're at an angle and at risk of impacting my other teeth. He keeps saying this will lead to infections and to pull them out now because pulling them much later in life can be problematic.
I just don't know if it's a scare tactic to drum up business, or if this is really something I should have proactively removed. I am not in any kind of pain currently, and I have regular x-rays done. Part of me says, if it ain't broke, don't fix it, but on the other hand, I don't want to ignore what may be a valid medical advice.
What would you do? Pull them now? Keep them until issues arise?
I am in my early 40s.
Thanks!
Similar situation, now 54 and still have all four. Was referred to oral surgeon in my early 40's or was it late 30's who said "Our cure is worse than your disease..." (quote). Angled to collide with rear most molars and not emerged through topside bone enough. Said the risk of damaging a certain jaw nerve to get at them and remove was in his opinion significant enough to leave them in until they cause problems. Said we damage that nerve and you slobber on your self rest of your life.
My father in law had a similar issue, exacerbated by limited access to dental care until he was in his 30's...after consulting with a couple colleagues, his dentist decided to go a bit outside the box for a solution: she removed the last molars (one of which was decayed), making room for the wisdom teeth. 20+ years later, her unorthodox solution is working fine. If they bother you...it might be worth at least asking about that solution.
