Winter Oil Test
Cajun Country, La.
The oils were poured at -20*.
This Q? is directed towards most of those in the very cold climates, but, everyone else is invited to give their opinions as well.
From what you have seen in this test, would it convince you to buy one or more of these oils for extreme cold weather start ups?
https://youtu.be/alnOguGvyh8
A bunch of 5W30s versus Rotella T6...the T6 behaved as I would have expected compared to the ILSAC 30s.
But the Castrol bottle tested was a Quaker State Bottle, so while they showed cracking the seal on the initial tests, we don't really know what they have in the Quaker State bottle...trust them, or trust Castrol...In a market with PQIA in it, I'd trust Castrol, and call foul on this one.
Personally, if I had an ambient morning of -20F, I'd have a test tube of every single oil in my stash stored outside and see how it performs inverted.
But going off THAT test...nah.
Obviously, if you lived somewhere that made you fire up your engine at -20 deg F you'd want the best flowing oil possible. A test like this shows which ones those are. I've heard engines fire up at below zero with thick oil back before synthetics existed, and it wasn't a pretty experience.
There is a bias in these tests since they pour from different containers. Taking that into account I definitely would, and I definitely have, adjusted my oil based on climate.
Some guy who does "testing" in his garage, just to post a video on the Internet? It is entertainment value, nothing more.
I posted this because I am not that educated in some areas of how and why oils work in certain conditions. I am not afraid to state this and ask Q?'s. The information I gather here gives me ammunition to go do searches on Google for more information to educate myself.
BOF: Pay attention to MRV and CCS if you're concerned about cold cranking, which shouldn't be a huge concern for you. Aside from that, pay attention to VI if you're concerned about viscosity at more normal startup temperatures, and gaining a tiny bit of fuel economy. Basically, if you choose an appropriate viscosity, it's not going to matter one bit of difference what label is on the bottle or what base stock is in it, assuming the specifications you want or need are met.
I agree to a point. One aspect of this pour test that does correlate to the real world is that Castrol is a bit thicker at cold temps than some other oils. This pour test does verify this phenomenon rather well. Question I have is what MRV is so high that a car/truck wouldn't be able to start??
Easy conclusion...Dont use Rotella or Castrol in the winter. Maybe I should say when it's cold outside. It's suppose to be 60 deg's Saturday.
Well, it's one data point, and it really doesn't tell us a whole lot. That's one reason VI exists as a measure, too, because two equal grades at KV100 might not be so equal at KV40. And, some oils truly do have pour points that suck. There's no doubt about it. But, pouring and pumping are not the same.
With respect to having an oil with an inappropriate MRV, well, a couple things can happen. Normally, if the oil is simply too thick, you simply won't be able to turn over the vehicle fast enough to start it. Sometimes, that's a good thing. Back in the days when carbs were more prevalent, you could fairly easily get a vehicle to start when it certainly wasn't in its best interest. When I was young, a buddy and I picked up a Duster to sell off. It had 10w30 in the sump, and had no problem starting unaided in -40. 10w30 is certainly overmatched by -40, particularly unaided. It started, but I doubt I was doing it any favours.
With a fair number of fuel injected cars over the years, I've found that if you're running something that's more appropriate as a summer weight, when it hits those ridiculously cold temperatures, it won't turn over fast enough to catch. With a vehicle with a carb, at least on every vehicle with a carb I've owned, if the battery is decent, and you do things "right", it's going to start, even when you probably shouldn't do so.
The Imperial Oil Esso video on YouTube about 0w30 gives a good example of using an improper winter viscosity oil versus using a proper winter viscosity oil, in what we'd call actual cold cranking temperatures.
Yes, they use the pour point demonstration. And no, this doesn't mean you need a 0w30 in 20 F. Look at the five minute part, to watch the start. Also, look at after the eight minute part, to see an appropriate oil being pumped, and an inappropriate oil being pumped. You want the oil to be able to be pumped in the temperatures you're facing when you start your vehicle. Right now, it's -3 C here. 15w40 will work fine. When it gets to -35 C to -40, a 5w-XX or better is my choice. And, I can run it all year, too.
Where I live it gets -25C every year, and on some years even -30C. In these temperatures I'm totally happy with 5W-oil.
But wouldn't a 0W-oil be more suitable for your (extreme) climate? Even mandatory? I just wouldn't dare to rely on 5W-oil at -40C.
No, there's an easier one...use a 0W if you need a 0W.
Don't use a 5W if you need a 0W, and running a dodgy test of 5W at (-40 ???) doen't prove what oil works best at -40...especially if there's a 0W available.
I have been curious what is the best oil for winter. mainly amsoil or mobil 1.
We get -40 min every year. truck is parked outside, I am getting a oil pan heater soon.
those videos to me are flawed. bottle spout and are they all the same grade?
Don't use a 5W if you need a 0W, and running a dodgy test of 5W at (-40 ???) doesn't prove what oil works best at -40...especially if there's a 0W available.
Your right...at -40 you should be using a 0w. But it does give you an idea how thick a 5w is... at those temps. Funny thing is Lucas is thicker than any of those at 50f.
This comment on the video makes the most sense to me:
*First off you didn't start the pour simultaneously*
I didn't see from the OP video link what viscosity they were using. they never showed the bottle labels to confirm they were all the same vis, so my contention is the show was rigged until proven otherwise. All I heard was brand names. Seems funny the Mobil would be faster than the Amsoil. Amsoil sources a lot of their base oil from Mobil.
