I've been playing with the RC (build 7100) release on the following machine I built for video encoding:
Tyan S2895 motherboard
Two AMD Opteron 285 processors (4 cores @ 2.6ghz)
8GB RAM
ATI Radeon 4870x2 video card
3Ware SATA RAID controller
4 Seagate 7200rpm 1TB disks as a RAID0 array
some cheap-o 20X DVD burner
This machine used to run mostly Linux (sometimes Ubuntu and sometimes CentOS 5.3), but I have to say that Windows 7 is growing on me, even with all the eye candy turned on (though this machine is likely so fast that the eye candy on/off is more an aesthetic issue than a performance one). I tried Vista on the machine about a year ago and I had stability issues so I went back to Linux.
Do I like it better than XP? After the initial learning curve, I'd have to say yes. Does it feel faster than Vista? Yes, it sure does. I'm using it quite a bit now and still dual booting back into Ubuntu when I need to get real work done (my video encoding workflow is all based on Linux).
All of the OS's mentioned above were the 64-bit versions. I've been toying with the idea of playing around with the RTM 7600.16385 build, but the 7100 build has been working well and I just don't have the spare time to fiddle with it. Anyone else here gone that route yet? Seems like if you stick to the RC/7100 build you've got a solid 6 months of legitimate freeloading before M$ asks you to dump or get off the pot whereas the RTM would necessitate a valid license key in a month or two. While Win7 seems nice, I don't think I'd pay a few hundred bucks for it just to scratch the occasional Crysis itch.
8GB RAM
