- Joined
- Jul 4, 2022
- Messages
- 15
Will a centrifugal engine oil filter work with multi vis oils? Or will the centrifuge seperate the different oils
Will a centrifugal engine oil filter work with multi vis oils? Or will the centrifuge separate the different oils
What year is that tractor?Thanks. My farm tractor is factory equipped with a centrifugal filter and usually has some crud that has to be removed when cleaning. The oem spec is for single vis oil type of 30 or 40. I wonder if i could use a 15w40 product or maybe a 5w40?
I would give the tractor manufacture a call and ask if they now recommend a multi-viscosity oil for use in the older models. If they make the same kind of tractor today, what do they recommend for oil viscosity in those today that have a centrifugal filter?I have two. One is a 1994 and the other a 1995.
I can't think of a reason why multigrade oil wouldn't be fine for the centrifugal filter. I've got a dirt bike with a centrifugal filter, and it specs 10W-40.Thanks. My farm tractor is factory equipped with a centrifugal filter and usually has some crud that has to be removed when cleaning. The oem spec is for single vis oil type of 30 or 40. I wonder if i could use a 15w40 product or maybe a 5w40?
And just to be clear, a multi-viscosity oil is not “different oils”. It may sound like it to you from the name, but that’s not how it works.Will a centrifugal engine oil filter work with multi vis oils? Or will the centrifuge seperate the different oils
No it will not remove additives. You can’t use a centrifuge to remove compounds that are in solution. Even if you could the centrifuge on your tractor produces nowhere near that kind of g-force.Thank you again. I think you are correct about the 15w40. I just didn't want the filter to spin out the additives. Wasn't sure if it would even be a problem or not.
Yes sir thank you. That was a poor choice of words from my description.And just to be clear, a multi-viscosity oil is not “different oils”. It may sound like it to you from the name, but that’s not how it works.
He could use some non-VII HPL multi-viscosity oil if the price doesn't scare him away. Every oil can be looked at as some "multi-viscosity" due to what it goes over temperature changes, but some like what HPL makes can meet the SAE multi-viscosity grades (per SAE J300) without VIIs.I can't think of a reason why multigrade oil wouldn't be fine for the centrifugal filter. I've got a dirt bike with a centrifugal filter, and it specs 10W-40.
I would not use a 5W-40 in an engine that specs SAE 30 or 40. It will be much thinner than the straight grade oils when it's subject to high shear rates. A 15W-40 would be more similar to an SAE 30, and a 20W-40 or 20W-50 would be more in line with an SAE 40.
