Originally Posted By: webfors
Answer: They can. Chances are they are more expensive than a 5wXX or 10wXX, so it's a waste of money when average temps don't require it.
The same is true for High Temps! You dont see people hunting down the 0W-50 Eneos for when they live in Death Vallex, AZ! That oil is likely a 40wt. at Normal Temp anyway, not a 50..
I think a great example is 5W-40. Its the Euro formula on a lot of oils.. people SAY it is thinner than a 0W at cold temp, but when it warms up its closer to 40 than a 0W would be. (Thick 5, thin 40, and before yall chop my head off, talking about 5 NOT as a viscosity, but as a factor in the viscosity range of how thick it is vs a lower W nnumber of same KV.)
Always amazed me how you can run 0W-20 in a 7.4L Powerstroke, or whatever that V10 Excursion (Gasoline) is.
Are there those that believe Ambient Temp does not make a difference? For example, 110 degree steamy sticky sauna-like Miami in July, maybe hotter. Idling in traffic then drive for 40 minutes to beach. Thick Oil there? The cars that FF 5W-20 do fine... ?
