I'm seeing Castrol Edge Euro 5w40 and Penzoil Platinum Euro 5w40 - are these currently the two preferred main-stream oils for this viscosity and usage?
I'm mostly trying to get the higher viscosity, and i'm sorry, i have never quite worked out the HT/HS differences in oils - so whilst i do want that aspect, i also want the 40 aspect as well.If specifically looking for a w40, yes, I'd say the one's you've mentioned. But if your trying to get an oil with an HT/HS of ~3.5, also consider the Mobil1 ESP line in 0/5W-30.
You should. It’s a better indicator than grade of how an oil protects an engine.I'm mostly trying to get the higher viscosity, and i'm sorry, i have never quite worked out the HT/HS differences in oils - so whilst i do want that aspect, i also want the 40 aspect as well.
Ok, i can accept that - what good, mainstream oils have that, that are not Mobil1? (sorry, won't use Mobil1)You should. It’s a better indicator than grade of how an oil protects an engine.
I believe it depends on the manufacturer, VAG, has changed what they recommend. Since many of the Audi are Turbos this becomes an additional consideration. My co-worker had an Audi 1.8 turbo and he even reprogrammed the computer to make it faster and Castrol Euro was not recommended. I would likely chose Mobil 1 in Euro Spec.Castrol Euro 5w40 looks like it's at the bottom end of the viscosity for a 40 at 12.8 cSt.
Interestingly, Penzoil EuroL 5w30 must be right at the top of the 30 with a 12.5 cSt.
What i don't know, is if either of them is somehow a better oil.
Then choose the xW-40 that has thr highest HTHS viscosity (units in cP). The HTHS may or may not be shown by the manufacturer, you'll have to look at their spec sheets.I'm mostly trying to get the higher viscosity, and i'm sorry, i have never quite worked out the HT/HS differences in oils - so whilst i do want that aspect, i also want the 40 aspect as well.
Because people post things and don't understand what they are talking about. Castrol may have or had a marketing agreement with VAG which may have expired or lapsed. It means nothing. What matters is the approval since this is what demonstrates performance. Not brand.Curious why Castrol euro wasn't recommended in that tuned Audi, but i've seen info on here suggesting it's all group III?
True, but i'm looking for a 5w40 or close/equivalent in viscosity, it just so happens than what i've found is all Euro spec oils in that area.Meh, there is little point in an API license when discussion Euro approvals.
I'm new to that brand, i'm guessing that means it's not exactly mainstream and at $15/qt ?hpl pcmo 5w40. hths 4.248
hpl pcmo premium 5w40. hths 4.024
hpl pcmo premium plus 5w40. hths 3.971
hpl euro 5w40. hths 4.023
hpl super car 5w40. hths 4.023
