I took a peak under the car (2000 Subaru Outback) last night and noted that the front stabilizer bar (I think that's what it is) has sheared off on the driver's side at the frame mount/bushing.
How critical is this stabilizer bar? Can I drive with it like that for a couple weeks until I have a chance to replace it? I notice no difference in handling or anything.
I only looked under there because I was hearing a grinding/clunking sound in sharp right turns, which turned out to be the broken end of the bar rubbing against the inside edge of the tire. I then removed the link and broken end of the bar.
The bar runs up over the front jacking plate and above the exhaust so I'm not sure how hard it's going to be to replace.
The bar sheared when I was pulling out of McD's and I didn't see there was a car coming until I started to pull out so I gunned it and then I heard a sound like a gunshot going off under the car, but I didn't feel anything different and a cursory look around outside the car didn't show anything so I just thought I ran over something or maybe bounced off the curb.
