- Joined
- Oct 16, 2023
- Messages
- 102
Condition being equal the Stx is $550 the gx85 is $450 which is the better lawn mower?
Is the sx85 and gx85 similar I’m looking at a gx85The STX38. The STX38 would likely have a 12.5hp Kohler Command with pressure lube and the SX85 will have a 13hp flathead Briggs. They are both decent if maintained, but those Deere rear engine riders have some funky transmission set ups that can be problematic.
This is for the .5 acres? If so, you will have this until you are fertilizer for the grass.Snagged the little stx38 it’ll do good for what I need. Runs good is decent shape for its age. I’m happy with it.
Yes sorry I meant GX85 but keep typing SX85.Is the sx85 and gx85 similar I’m looking at a gx85
Yep sure is. I plan on keeping it as long as possible I cut the grass with it today and it did a great job. Cuts well feels tight and solid. Very happy with it so far.This is for the .5 acres? If so, you will have this until you are fertilizer for the grass.
No, those are the newer Kohler Courage engines. The Command on these tractors is a much better engine.Is it a yellow deck or black? I much prefer the S100 with the battery behind the engine than having that huge gas tank there.
Do these have the Kohler that likes to loosen the bolts and crack?
