OVERKILL
$100 Site Donor 2021
Originally Posted By: Astro14
There's no incentive to do what you propose: expensive new engineering tech for better MPG.
Toyota sells a ton of good MPG cars, so their CAFE is high.
The domestics sell a ton of pickups and have to use every trick to get those vehicles to achieve decent MPG so that they can meet CAFE.
I bought a Tundra specifically because it eschews the gimmickry that the domestics have piled into their trucks. I simply don't trust that all that tech will be reliable.
Give me a simple V-8, in a reliable truck. That's what I want, and, I think I'm not alone.
Well that’s the first time I’ve heard a GM small block or Hemi referred to as “gimmicky” and having “all that tech”.
Both have cylinder deactivation. (At least in the 1/2 ton models, comparable to the Tundra).
That's a gimmick.
And a tech solution purely for fuel economy.
I don't care to discover the long term durability of those systems first hand.
Add in these "features":
Push button eight speed transmission
Radiator shutters that vary with speed
Variable intake runners
Twin turbo V-6s
Air ride
I like the Hemi. I've owned several SBCs. I don't mind the aluminum body parts, and I'm not afraid of tech (with a twin turbo V-12 that has active suspension).
But the new crop of the Big 3 1/2 ton pickups are riddled with new features and tech that has yet to be proven. The Tundra's V-8 is straight forward and sounds great when you rev it up. The 1794 interior is more simple and more elegant than the domestic competition. The truck itself is old school under the skin.
And that's what I really wanted - simple and reliable.
I don't care about the MPG.
Variable intake runners have been in use since at least the 90's, that's not new tech. As I mentioned to hatt, MDS has been around for at least 12 years, again, not new. The ZF 8 speed transmission has also been around for quite some time and has been put behind the 707HP Hellcat mill, if there were durability issues with it, they would be discovered in that application.
Saying MDS is a gimmick because its purpose is for fuel economy benefits is a slippery slope.
- Fuel Injection was also designed for this purpose
- Port injection, as an improvement to TBI increase efficiency yet again
- Direct injection, the latest incarnation has been more problematic than MDS could ever hope to be
- Oxygen sensors instead of running on base table, and then wide-band oxygen sensors
- Lean-burn ECM programming
- Electronic throttle bodies
- Variable camshaft timing
How far are we going to go with this? [censored], we were chasing fuel economy with lean-burn carbs back in the 1970's, EGR is also intended to aide in fuel economy.
It's a gimmick if its actual impact is far less than claimed and primarily serves as marketing malarky, MDS doesn't fall into that category, IMHO, it actually does yield significant improvements in fuel economy and that's why my DD gets reasonable gas mileage while making 470HP out of a 6.4L V8.
Radiator shutters that vary with speed? That's more of a gimmick here, IMHO, as the benefit will be nary zero, but the added complexity and potential for issues? Significant.
That's a gimmick.
Twin turbo V-6s
Air ride
