Kestas
Staff member
The only way sitting could cause damage is if the seal failed, allowing static corrosion to occur. But even that is a long shot because water would degrade the grease to where the bearing would suffer lube failure.
In our wheel bearing warranty return, the primary reason for early failure is water ingress from a bad seal. There are other reasons, but we are guessing. Only a proper examination would let us know. Never have we found a bearing that failed in warranty because "it sat too long."
