which would you choose and why? Easiest to obtain and most affordable at Walmart
Did any out perform the other in any way?I've used MaxLife, Castrol Transmax IMV & CVT...BUT not Universal all with excellent success.
What do politics have to do with choosing transmission fluid? As to which one, unless going into a beater, neither. Get the specific fluid for your transmission whether it takes Dexron, Mercon, Mercon LV, Honda, or CVT. While those are unlikely to damage a transmission, I can imagine shift quality, feel and general performance might not be the best, especially in a CVT. How can a fluid made for conventional transmission work properly in CVT's?Politics aside, which would you choose and why?
You cant mention or get into politics on this forum or it gets locked.I say politics because people don’t use Castrol because of the oil spill or something that happened
I should add that, sometimes after an ATF change(drain/refill), I think(keyword THINK) that I feel/hear something different. Not different in a bad way just different in, Ohh, say the shift points and engine revving @WOT. However that feel/sound/whatever seems to go away in a few days so, chalk it up to PLACEBO.No, not that I could tell.
Honestly, I am willing to bet each is as good as the next with proper flushing and refills per manufacturers schedule.which would you choose and why? Easiest to obtain and most affordable at Walmart
View attachment 91641View attachment 91642
