well I'm not talking about washer fluid, sorry to throw you guys off. I'm just talking about things in general. Like my pressure washer pump etc. I'd just rather keep things from freezing in the first place.
Just do the math.
How big is the footprint, how tall is the ceiling, what is the insulation like?
So let’s assume you have an 8x10 shed with a gable roof so the average height inside is 12 ft. The shed is uninsulated. Everything will retain some heat, have some solar radiance, it doesn’t stay that frigid for that long. So let’s assume that your design is to raise the temperature 30 degrees…
The calculator says:
(insulation*volume*temperature rise)/1.6=BTU/hr.
So:
(5*(8*10*12)*30)/1.6=90000 BTU/hr=~26kW!
Even if we get rid of the substantial factor for no insulation, so say,
(1.5*(8*10*12)*30)/1.6=27000 BTU/hr=~8kW!
Frankly, I believe this completely. I installed a 5-6kW 240v garage heater (heating coils with a blower), in my uninsulated multi-garage building, to heat one bay. They bays are 10x20, with no ceiling, and a roof peak of 16ft or so. So obviously heat rises, no insulation makes for big losses, etc., etc.. the bay I have it in is more like 20x20, so a big space.
I can only get a few degrees rise in the building when running for a few hours at a time. It’s enough to go in, close the door, and take the chill off. I don’t run it all the time, so it’s not a big concern, and it does add comfort when not super cold and everything is cold soaked. And that’s a larger space, higher ceiling, etc., but kind of the same thing.
So your numbers could be huge if you’re truly trying to avoid items from freezing in conditions where the max low temperature is encou;there’d, based upon temperature rise required and losses from the building. Insulation and reduction of ceiling height are the two main knobs to turn then…
