Originally Posted By: Tegger
Originally Posted By: Carnoobie
im double checking right now on whether this cars shoes auto adjust by going fwd or backwards. Im pretty sure its R though cause this car is different from most.
It is a bit different, but not in the way you're thinking of.
The adjustment mechanism is at the top of the assembly, right under the hydraulic cylinder.
The adjuster lever (on the leading shoe) has two arms: "A" and "B". The lever is pulled downwards by a spring. That force makes arm "A" sit against the adjuster (clevises and star wheel) while arm "B" is poised above the star wheel. When you step on the brakes, the shoes move apart, causing the adjuster to be pushed away from the lever by the action of arm "A" and its spring, allowing arm "B" to dip down towards the star wheel.
Once the shoes wear enough, the dipping action of arm "B" becomes sufficient to turn the star wheel a little bit. All that's required is to step on the brake pedal to push the shoes apart. The spring and lever do the rest.
ill double check to make sure my tensioner turning knob is facing the right. Gonna take it to one of my mechs in a bit.
+1 on the e-brake cable, it helps the adjusters on a lot of cars, especially chrysler k cars.
Go for a drive, try to gain speed but don't use the brakes, just coast up the hill to a stop. Quickly pull the drum and check the brake shoes for heat. If they're hot on the wheel cylinder side you have a line pressure problem, hot on the adjuster, there's your issue.
Why don't you just take detailed pictures of your brakes with the drums off? A honda expert might say, oh, your spring hardware kit is in backwards and rubbing, or something like that.
ill take some pics
When you say no play, do you mean when wiggling the drum (when its on the hub) side to side or forward and back? and are we talking with the drum bolted in or just by hand?
The hub and the hole in the drum should be exactly the same size (with a few thou tolerance).
With the drum fully-seated ON the hub, and the wheel and the parking brake OFF, you should not be able to shift the drum front-to-back or up-and-down. The only available movement should be a bit of rotation, on account of the fact that the holes for the wheel-studs are slightly larger than the studs themselves.
From what i last remember theres no give at all when the drum is on and bolted on.
