I have a 99 Tahoe. I pull a 3000 lb boat. The manual says to use OD/Drive with a circle around it unless you are in hilly terrain.
At freeway speeds the rpm drops from about 2500 to 1700 when I shift from 3rd to OD.
My typical haul is 75 miles on flat ground at 75 mph. The last 40 miles are a mix of flat ground and some fairly steep hills at 60 mph.
Should I leave it in OD and let in downshift, or drop it in third? I don't mind running the higher rpms and using more gas if it is saving the tranny.
